 Post subject: Not redy!
PostPosted: October 9th, 2008, 13:53
Hi to all!!
2,5" SATA 100 GB
MODEL HTS721010G9SA00
This hdd suffered to a fall, off and the interesting one that it moves heads normally as if was ok and later return for the rest. Them to platter IN visually ok and heads also! In it reports mhdd me:
in (F2)
not ready!
DRSC DRDY ABRT
HEADS DISALIGNED?
I MUST MAKE THE HEADS EXCHANGE?
:idea:
Нет ничего невозможного
 Post subject: Re: Not redy!
PostPosted: October 9th, 2008, 14:25
Initialization error
Error : Error switching to techno mode
Selected family......................... : HTS726
Model by ID............................. : <ID IS NOT READ>
NV-RAM reading........................................................ : Error
Log universal utilities
Bus test started (ports x2, x3, x4, x5)
Writing "00" to ports
Status.................................. : Ok
"Running set to one bit" test
Writing "FF" to ports
"Running set to zero bit" test
Errors not found
Status register reading process started ...
Status register reading process interrupted
Cyclic NOP sending
Sending of NOP command interrupted".
Sector buffer test
Ok
Write sector buffer error (ABR) 51 / 04
IRQ Test
Ok
HDD does not support set max LBA
HDD does not support S.M.A.R.T.
Write cache............................. : not supported
Soft reset ...
Ok
Errors not found
IRQ Test
Ok
Soft reset ...
Ok
Sector buffer test
Ok
PostPosted: October 10th, 2008, 10:16
U do not seem to use the proper utility for this family.
PostPosted: October 10th, 2008, 13:31
Yes my friend!!
Some help?
Users browsing this forum: Google [Bot] and 74 guests
