 Post subject: Seagate CF drives
PostPosted: October 10th, 2008, 13:32
Anyone have any experience with these? Common problems, success rate, etc. I just received one, and it doesn't seem to be drawing any power on my oscilloscope, (~3-4ma on the 5v). I can't detect and noise or vibrations coming from the drive; and obviously it does not identify, or initialize. It looks like it may be PCB.
Model: ST650211CF
P/N: 9AF212-235
FW: 3.04
Date: 05341
 Post subject: Re: Seagate CF drives
PostPosted: October 10th, 2008, 13:48
no noise at all? first check the power input circuits and protections
PostPosted: October 10th, 2008, 14:20
Usually, the protection is before anything.
If fuse is blown, the unit can't get 3-4 mA.
This is only opinion. :)
Regards,
Janos
PostPosted: October 10th, 2008, 15:14
Model: ST650211CF
P/N: 9AF212-235
FW: 3.04
Date: 05341
Pardon Me ,
How Are You Passing current Via a Scope ?
PostPosted: October 10th, 2008, 15:49
I have a beta unit of Atola insight; which has a built in oscilloscope
PostPosted: October 10th, 2008, 15:51
Anyway, it is done with measuring only one good value resistor, connected serially with the unit. ;)
Janos
PostPosted: October 10th, 2008, 16:00
Atola's "oscilloscope" is not an oscilloscope, is a graph of a current monitor readout. For oscilloscope I mean , just to say, a Philips PM3217 or a Tektronix or HP...
PostPosted: October 10th, 2008, 16:20
Janos
Pardon Me ,
I Ask the Same question again How ?
PostPosted: October 10th, 2008, 16:24
Let the current flow through a fixed value resistor and then measure the voltage (Ohm's law)
PostPosted: October 10th, 2008, 16:35
i think the 3 to 4 mA on the atola is parasitic noise. check the circuit protections (diodes, ferrites, TVS) just to be sure
PostPosted: October 10th, 2008, 17:16
Amarbir, this is the correct answer. :)
Good scope can measure from some mV lost in the resistor, so you can use a very little value, or a simple long wire, as Dmitry sad. :)
Janos
PostPosted: October 11th, 2008, 14:49
Janos
Janos ,
Measure Milli volts But Current ?
PostPosted: October 11th, 2008, 15:35
Janos
Janos ,
The scope can measure mV, of course.
But you can measure Current with it, if u use one resistor as well. R = U/I ( if i remember right. :lol: )
Janos
Users browsing this forum: Majestic-12 [Bot] and 55 guests
