 Post subject: exchange of heads SP0842N
PostPosted: October 15th, 2008, 11:15
Hi to all!
Please info:
exactly fw, exactly model, manufactured in different countries (Brazil and Korea)
it has heads compatible for exchange? (look photo)
Thanks advance!!
Нет ничего невозможного
 Post subject: Re: exchange of heads SP0842N
PostPosted: October 15th, 2008, 11:45
Hello sempre
Could be compatible , but check inside preamplifier, i had check at some cases at samsung even if u got , same model, same P/V preamplifier could be different
PostPosted: October 15th, 2008, 12:56
There is always a chance that it may be compatible, but in most cases with samsung a county match is needed.
Check preamp.
PostPosted: October 15th, 2008, 14:02
I have had a high success rate with samsung drives just matching the last 5 of the P/N barcode
In yourcase P/V FS
I also ignore country but try to match drive size & model
Ive also had the odd one work from differant models but match the last 5 of the barcode
hope this helps
PostPosted: October 15th, 2008, 14:31
Hi Sempre ,
Do Check The Preamp Man ,Highly Suggested
PostPosted: October 15th, 2008, 15:23
Thanks all replys!!
:idea:
PostPosted: October 15th, 2008, 15:40
Material mixing (the "FS" code) is mandatory and also the last digits of barcode. Confirmed.
Samsungs are not so "picky" for HE in my stats, expect some hiccup when imaging because of different adaptives, unless you have a workaround for this problem. Anyway the density is not that high, so with high probability the imaging will be rather smooth.
Users browsing this forum: Google [Bot] and 104 guests
