 Post subject: need loader for maxtor 94610H6 BAC51KJ0
PostPosted: October 15th, 2008, 10:30
drive is a 46.1GB DiamondMax 60. BAC51KJ0 CMDA pcb code G8DNB. Thanks!
 Post subject: Re: need loader for maxtor 94610H6 BAC51KJ0
PostPosted: October 15th, 2008, 10:47
also this is for a maxtor ALTAIR series drive which I can find remarkably little info regarding online.
PostPosted: October 16th, 2008, 12:13
This drive family was never supported by PC3000.
PostPosted: October 16th, 2008, 14:33
Yeah, I was unable to find any info about them in the documentation.
So.... what now? If you have one of these drives that needs DR you're just out of luck?
PostPosted: October 16th, 2008, 14:40
You never mentioned what the symptoms were.
PostPosted: October 16th, 2008, 23:17
Typical maxtor problem... Detects as Maxtor ALTAIR, does not click when it spins up.
PostPosted: October 17th, 2008, 10:23
Doesn't sound like heads but it's possible. First try hot swap with similar model. If you are able to access sectors after this you may be able to use Data Extractor to rebuild virtual translator. Good luck.
PostPosted: October 17th, 2008, 12:24
Or you can use older version of pc3k isa V14 that works with these models .
PostPosted: October 17th, 2008, 12:47
Thanks for the insights... I was able to get it working with the Salvation tool.
