Forum rules
 Post subject: simplest way to make maxtor detect as ATHENA etc?
PostPosted: October 17th, 2008, 14:36
For demonstration purposes, what would be the simplest way to cause a functioning maxtor drive detect only as ATHENA or whatever family name it has? I was under the impression that a corrupted header in the g-list or p-list would cause this behavior, but I have been having trouble inducing it on purpose on a drive I have here by writing random bytes over the TAP_LD1 and TAP_LO1 bytes in these modules.
 Post subject: Re: simplest way to make maxtor detect as ATHENA etc?
PostPosted: October 17th, 2008, 15:50
Just hit it very hard! It would be the simplest way.
www.datarecoveryne.com
PostPosted: October 17th, 2008, 17:53
Nooo... Simply put some trash in the copies of g list... Or on 1f - Disk. Easy to recover after the lesson.
PostPosted: October 17th, 2008, 22:06
There are two copies of critical modules on Maxtor drives
PostPosted: October 18th, 2008, 1:59
In fact I said COPIES, plural...
PostPosted: October 18th, 2008, 11:11
I think part of the problem is that the disk I was using (a 94610U6) is not properly supported... Looking at the module list I'm not convinced that it was mapping them out properly.
PostPosted: October 18th, 2008, 17:55
Can you post pics of label and pcb? Thanks.
PostPosted: October 18th, 2008, 22:37
I won't be back at work until Tuesday, but sure.
What concerned me is that when I opened the saved modules in a hex editor, it looked like there were headers for other modules later on in the files.
PostPosted: October 20th, 2008, 7:26
Are you using ISA PC3000?
PostPosted: October 22nd, 2008, 15:45
no, salvation data hd doctor.
here's a pic of the label and a fuzzy one of the pcb... all I had here to take pictures with was a customer's flatbed scanner so the pcb one isn't so great.
