 Post subject: UDMA update 4.04 is out (english) anyone got it yet?
PostPosted: October 23rd, 2008, 21:32
 Post subject: Re: UDMA update 4.04 is out (english) anyone got it yet?
PostPosted: October 24th, 2008, 2:36
I have :-)
Dobre
Murphy was an optimist
PostPosted: October 24th, 2008, 6:28
me too :O)
PostPosted: October 24th, 2008, 7:42
I got it , fantastic improvement :D
PostPosted: October 25th, 2008, 18:35
Not that much frankly for new major(4.0) version.
Kernel
-Some User Interface enhancements.
-Profile handling improved.
-Utility start with parameters added(actions to perform on utility start: do not read ID, perform SW/HW reset)
-Ability to cancel search in database added.
Universal utility
-Verification test optimized.
-Customization for Read/Write/Verify tests.
Samsung
-Terminal baud rate increased to 128000
-Handling track defects optimized.
-Terminal baud rate adjusted automatically on start-up.
-Added families: STORM2, TRIDENT3.
-Defect list handling improved for some families.
-Utility start menu revisited.
-Reading by CHS mode exported to Data Extractor.
-ROM writing for Delphi and Poseidon families implemented.
IBM-Hitachi
-NVRAM adjustment algorithm implemented for SATA drives(search beginning address of SA with non-original NV-RAM)
-Password reset algorithm made easier(no testpoints shortening required)
-Custom families handling improved to use with NV-RAM adjusment algorithm.
-Further Data Extractor integration(some utility functions exported to Data Extractor to provide more reading and error/timeout handling capabilities).
WD Marvell
-LDR loading redesigned(to start drives that get hung and do not ID at all).
-ROM restoration mode added for ROYL drives. Allows to rebuild ROM based on HDD SA or SA resources.
-Cancel button on utility start(to stop utility initialization in case the drive hangs).
-Module reading-writing improved.
-Factory self-test added.
-Working with module copies improved.
-Internal hardware way of checking modules added in "Modules directory" and "SA Structure test" modes.
-Error handling improved.
-Readable vendor-specific errors reporting implemented.
Seagate
-Some specialized commands are now exported to be used by Data Extractor to facilitate imaging drives with bad media: loading App, Ovl0, Cert.
-Ability to modify App code to prevent drive from starting "offline scan" during imaging. Greatly improves imaging speed on drives with degrading media/heads.
-5400.3 family(VENUS) added.
-Further Data Extractor integration(some utility functions exported to Data Extractor to provide more reading and error/loss handling capabilities).
Maxtor
-Loader loading algorithm optimized for Sabre2, Sabre, N40PSATA families.
-Hardware translator regeneration implemented (by the drive itself - much faster than software regeneration)
-Software translator regeneration algorithm optimized.
-Autorecovery mode using LDR implemented.
-SA structure report improved.
Quantum
-Modules table reading algorithm improved.
Fujitsu
Data Extractor
-Filter view implemented to display only needed files in Explorer view based on file mask.
-NTFS and HFS+ handling minor improves.
PostPosted: October 31st, 2008, 12:43
yes i get it Also.
ZeBong
ZeBong
" Россия еще раз"
PostPosted: November 1st, 2008, 7:15
Banned User
how much the udma ????
www.njzhaobo.com
PostPosted: November 10th, 2008, 17:11
A lot. Call them
PostPosted: November 14th, 2008, 6:25
udma is about 2800 euros. I bought it a half year ago. yepp, call them :)
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: November 14th, 2008, 6:36
Just as a side thought.
I wish they would test the dam updates before release. I have found some problems... Grrrrr I will live BUT for the cash and the time waited I would expect a more pro release
PostPosted: November 14th, 2008, 6:42
I have a problem recovering from HFS volumes, the utility simply freezes when recovering some of the HFS files such as .DS_STORE. Not very easy to exclde these files as they are embedded in sub-directories also.
Anyone else have this problem?
