 Post subject: Maxtor 6y250m00656ab Advice
PostPosted: October 24th, 2008, 6:31
Hi Guys. I need some advice. Having trouble sourcing an exact match for this drive....
6y250m00656ab
YAR51FW0 KMGD
I have managed to find a few close matches.
6y250m00656ab
YAR51FW0 KGCD or NMCD
and some not so close....
6Y250P0062211
YAR41BW0 KMGD.
so my questions, which donor drive if any should I use for a head stack replacement?
I normally try to match firmware, 4 letter code and model, do these drives need such strict requirments for donor drive compatibility?
HDD Spaz.
 Post subject: Re: Maxtor 6y250m00656ab Advice
PostPosted: October 24th, 2008, 7:02
6y250m00656ab
YAR51FW0 KMGD
6y250m00656ab
6Y250P0062211
YAR41BW0 KMGD.
HDD Spaz.
This one
6Y250P0062211
YAR41BW0 KMGD.
The 4 letter code matches for head and preamp match, and the 06 in the model determines head type also
PostPosted: October 24th, 2008, 7:21
Cheers HDDGuy,
I hope your right. That contradicts what is says on the HDD Guru Head Replacement FAQ document but I'll give it a go.
Anyone else got any thoughts?
PostPosted: October 24th, 2008, 8:33
KMGD and 06 would be sufficient, material mix do match. P.s. Yar41bw0= likely REFURB DRIVE, so beware ;-). Expect slow imaging because of differences in heads! Post the result.
PostPosted: October 24th, 2008, 9:16
thanks.
I will order parts today, will post results Tuesday.
PostPosted: October 24th, 2008, 11:38
Totally agree
BlackST wrote:
P.s. Yar41bw0= likely REFURB DRIVE.
Have to totally disagree YAR41BWO is a regular firmware for DM9 drives
www.datarecoveryne.com
PostPosted: October 24th, 2008, 17:32
Here we have tons of drives with that fw clearly written 'REFURBISHED TO MAXTOR SPECIFICATIONS' and/or one label over another. Also heard this from other tech.
PostPosted: October 24th, 2008, 18:30
I have loads and loads of DM9 with firmware yar41bw0... I think more likely is just that these drives failed so often that there are more refurbished ones out in distribution than other models.
PostPosted: October 24th, 2008, 19:38
I have refurbished thousands of DM9 drives, but Code: YAR41BWO is just a firmware nothing more. :lol: Yes, i have seen a lot of Refurb. drives with different types of FW. This does not mean that all drives are refurbished. :D
You must of got a big load of previuosly ref. drives in Italy :mrgreen:
Maybe its a coincedence, but I used to buy a lot of returned drives from a company in Italy and a lot of them were previously refurbished, but that was a long time ago.
PostPosted: October 25th, 2008, 1:44
I meant brand new, off the shelf and bag sealed. Perhaps is a coincidence... P.s. All the drives with 'refurbished' label I had for dr, suffered from bad head crash and ground surface.
Users browsing this forum: Google [Bot] and 219 guests
