 Post subject: WDC WD2500JB-22GVC0-08.02D08-WD-WCAL74471902 problem
PostPosted: October 24th, 2008, 22:56
i have WDC WD2500JB-22GVC0-08.02D08-WD-WCAL74471902
its starts good and 1/3 of hdd reads good, but other 2/3 of hdd almost all defected.
ERROR! LBA : 413 299 827 Verification error 48-bit (INF)
ERROR! LBA : 413 299 828 Verification error 48-bit (INF)
ERROR! LBA : 413 299 829 HDD Readiness timeout (200 ms)
ERROR! LBA : 413 299 830 Verification error 48-bit (INF)
ERROR! LBA : 413 299 831 Verification error 48-bit (INF)
ERROR! LBA : 413 299 832 HDD Readiness timeout (200 ms)
ERROR! LBA : 413 299 833 Verification error 48-bit (INF)
ERROR! LBA : 413 299 834 HDD Readiness timeout (200 ms)
ERROR! LBA : 413 299 835 HDD Readiness timeout (200 ms)
i tested on pc-3000 heads and SA surface, and modules- its perfect.
its imposible what theese all are bad sectors. maybe some problem with translator or dameged P-list. i did translator regenertion on P-list but no luck. the Hdd was given to make data backup, when it returned back it has this problem. now Hdd not contains any data. maybe it was connected bad or dropped, but if was dropped all hdd must be read bad not only the 2/3 of it. what the problem can it be?
Techno mode key:
HDD geometry loading.................... : Ok
Cyl Count............................... : 87922
Head Count.............................. : 6
SPT..................................... : 900
RAM:
Zone allocation table................... : Ok
ROM version............................. : 21.17.
SA FW version........................... : 21.17J
Link table version...................... : 02.AA.
Serial ROM:
Read ROM................................ : Ok
Heads configuration..................... : From map
Heads number............................ : 6
The number of heads in use.............. : 6
Disabled heads.......................... : No
Head map................................ : 0,1,2,3,4,5
HDD ID reading.......................... : Ok
Heads test
Cylinder to test........................ : -25
Heads to test........................... : 0,1,2,3,4,5
Head 0.................................. : Ok
Head 1.................................. : Ok
Head 2.................................. : Ok
Head 3.................................. : Ok
Head 4.................................. : Ok
Head 5.................................. : Ok
 Post subject: Re: WDC WD2500JB-22GVC0-08.02D08-WD-WCAL74471902 problem
PostPosted: October 25th, 2008, 18:26
Did you do something with modules?
You can try to regenerate translator but most likely it's a media damage.
PostPosted: October 25th, 2008, 18:32
IDNF.
It looks SA issue.
I have no exact idea. :(
Try to find trash in modules....
Janos
PostPosted: October 25th, 2008, 18:39
If it was translator issue it would be IDNF right from the start and no readiness timeouts.
PostPosted: October 25th, 2008, 18:51
This is not always true.
Translator corruption can cause partial unreadable user space.
Additionally, the continous IDNF shows it is SA related.
The IDNF is _between_ the AMNF and the ABRT/UNC in read problem levels.
So, it is impossible to hiting always the middle level....
It is SA.
Janos
PostPosted: October 26th, 2008, 2:02
i think it is problem with SA too, but when i check modules and SA surface it gives me no error, its like only 2 3 and 4 5 heads reads good but gives error like the translator coruption. its strange - the 0 1 heads read without errors. how to be sure that it is translator? how to check it if it contains the trash and which module is corupted? modules 20 and 25 i cant take from other HDD, the translator is unicue, cause i have other 4 hdd of this model that are working good.
some idea how to solve the problem???
