Whilst trying to transfer data from a Seagate Barracuda 250GB 7200.9 Ser:4ND2DEV7 with a USB converter I stupidly got the IDE power supply connector around the wrong way (as hard as this might seem to do
) pushing it into the receiving connector of the adaptor. This smoked one of the components on the HDD circuit board. I'm hoping it is a protection cct of some kind and that replacing the obviously damaged component will fix the issue. Can anyone help me in identifying this component (see image) When I plug the hard drive in now with the adapter around the correct way it still smokes and the drive dosn't spool up.
Many thanks
Oh in the wider shot the component is the one at the top of the picture close to the SATA connecter second in from the left (on a bit of an angle)
