 Post subject: Need to know the compatibility of pcb
PostPosted: October 28th, 2008, 4:24
My friend has WD6400AAKS and he needs to change his pcb.
His pcb no. is 2060-701537-003 Rev A with CPU no. is 88i8845C.
Is it compatible if changed the pcb with the same number as above but different
CPU no. (just the last letter is different - 88i8845D)?
Thanks...
 Post subject: Re: Need to know the compatibility of pcb
PostPosted: October 28th, 2008, 21:53
PCB number is most important in my experience. You will probably need to transfer ROM contents which is difficult without special tools on newer WD drives that lack a physical EEPROM IC.
What are the symptoms of your friend's drive?
PostPosted: October 29th, 2008, 6:18
he just said that pcb was burned..over volt..
but if just to take out the data, is that possible to buy that pcb?
PostPosted: October 29th, 2008, 9:39
Probably, have you checked google and ebay? How about the buy/sell section of the forums here?
PostPosted: October 29th, 2008, 12:04
If data worth less then a new drive, forget about it.
www.datarecoveryne.com
Users browsing this forum: Google [Bot] and 55 guests
