Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
 Post subject: LDR Maxtor 6L080L0 needed
PostPosted: October 28th, 2008, 7:39
PLEASE!! LOADER!!
Нет ничего невозможного
 Post subject: Re: LDR Maxtor 6L080L0 needed
PostPosted: October 28th, 2008, 15:12
More info required!
PostPosted: October 30th, 2008, 8:52
pcimage wrote:
More info required!
Ok, my friend!!
PostPosted: October 30th, 2008, 10:20
http://files.hddguru.com/download/PC-30 ... tor/Sabre/
PostPosted: October 30th, 2008, 10:29
pcimage wrote:
http://files.hddguru.com/download/PC-3000%20Support/Firmware/Maxtor/Sabre/
Thanks!
Loader 100% tested?
PostPosted: October 30th, 2008, 10:31
I made from good HDD myself
PostPosted: November 10th, 2008, 14:18
Hi,my friend!!
when loading loader it of the one beaten and the errors (clicking)
:roll:
PostPosted: November 13th, 2008, 13:37
look error...
PostPosted: November 13th, 2008, 13:53
sempre wrote:
look error...
PostPosted: November 13th, 2008, 15:21
Try another loader!
Maybe you have head problem as well...
The platter is untouched on the motor?
Janos
PostPosted: November 13th, 2008, 15:36
N.C. wrote:
Try another loader!
Janos
another loader! ok not read...
Maybe you have head problem as well... probably head bad
engine has rpm normal and it does not beat normal binding, only beats (clicking) when I try to load loader…
:roll:
PostPosted: November 13th, 2008, 16:10
sempre wrote:
N.C. wrote:
Try another loader!
Janos
:roll:
I mean are you sure, about nobody have touched the screws wich fixing the platter?
The issue is similar, if the platter is off-track, unaligned.
Janos
PostPosted: November 27th, 2008, 13:57
Hi to all!
after exchange of heads
Read roadmap............................ : Ok
Read roadmap extension.................. : Ok
Read zone allocation table.............. : Ok
Read Technological ID................... : Ok
Read Zone allocation table extension.... : Ok
U_LIST has been found for the head...... : 3
SA head................................. : 3
Ext Model............................... : 6L080L0021P11C
HDD structures have been read successfully
Reading modules
Into folder............................. : <HDD Profile>\Data\Modules\Head3\
Module 00............................... : 47F60002.rpm
Module 01............................... : 47F80002.rpm
Module 03............................... : 47FA0001.rpm
Module 04............................... : 47FC0078.rpm
Module 05............................... : 488A0001.rpm
Module 08............................... : 488B0001.rpm
Module 09............................... : 488D0001.rpm
Module 0A............................... : 488E0001.rpm
Module 0B............................... : 488F0001.rpm
Module 0C............................... : 48900001.rpm
Module 0D............................... : 22DA0003.rpm
Module 0E............................... : 22DD0008.rpm
Module 0F............................... : 22E50001.rpm
Module 10............................... : 22E60002.rpm
Module 11............................... : 22E90001.rpm
Module 12............................... : 252608E8.rpm
Module 13............................... : 22EB0008.rpm
Module 14............................... : 24A6000B.rpm
Module 16............................... : 24D20040.rpm
Module 18............................... : 00290139.rpm
Module 19............................... : 01910001.rpm
Module 1A............................... : 01920001.rpm
Module 1B............................... : 02AB0032.rpm
Module 1C............................... : 01A60002.rpm
Module 1D............................... : 02A90002.rpm
Module 1E............................... : 018E0002.rpm
Module 1F............................... : 00080001.rpm
Module 20............................... : 02DD0002.rpm
Module 21............................... : 0162000B.rpm
Module 22............................... : 01A40001.rpm
Module 24............................... : 359A01B2.rpm
Module 25............................... : 44DA0008.rpm
Module 27............................... : 374C000C.rpm
Module 28............................... : 375806C8.rpm
Module 29............................... : 3E200020.rpm
Module 2A............................... : 48910001.rpm
Module 2B............................... : 4892000C.rpm
Module 2D............................... : 489E000C.rpm
Module 2F............................... : 01930001.rpm
Module 30............................... : 01940001.rpm
Module 32............................... : 01A50001.rpm
Module 33............................... : 1ADA0800.rpm
Module 34............................... : 01A80100.rpm
Module 37............................... : 00040001.rpm
Module 38............................... : 0A6800A0.rpm
Module 39............................... : 09680100.rpm
Module 3A............................... : 44EA0028.rpm
Module 3B............................... : 44E20008.rpm
Module 3C............................... : 45120050.rpm
Module 3D............................... : 45620100.rpm
Module 41............................... : 01960002.rpm
Module 42............................... : 25230003.rpm
Module 43............................... : 22E80001.rpm
Module 44............................... : 01900001.rpm
Module 45............................... : 0198000C.rpm
Module 46............................... : 24B1000B.rpm
Module 47............................... : 24BC000B.rpm
Module 48............................... : 02A80001.rpm
Module 49............................... : 23A30020.rpm
Module 4A............................... : 24A40002.rpm
Module 4B............................... : 3E400001.rpm
Module 4C............................... : 22EA0001.rpm
Module 4D............................... : 47FB0001.rpm
Module 4E............................... : 488C0001.rpm
Module 4F............................... : 0B0804A0.rpm
Module 54............................... : 3E410004.rpm
Module 55............................... : 3E490002.rpm
Module 56............................... : 22F300A0.rpm
Module 57............................... : 3E4F000C.rpm
Module 58............................... : 25120011.rpm
Module 59............................... : 2E0E000C.rpm
Module 5A............................... : 48740008.rpm
Module 5B............................... : 487C0002.rpm
Module 5C............................... : 487E000C.rpm
Module 5D............................... : 48AA0003.rpm
Module 5E............................... : 02F80111.rpm
Module 5F............................... : 48AD0001.rpm
Module 60............................... : 3E4B0004.rpm
Module 61............................... : 2E1A0001.rpm
Module 62............................... : 2E1B0001.rpm
Module 63............................... : 01950001.rpm
Module 64............................... : 02E00001.rpm
Module 65............................... : 02E10009.rpm
Module 66............................... : 02EA0009.rpm
Module 67............................... : 02F30005.rpm
Module 68............................... : 22DC0001.rpm
Module 69............................... : 23930010.rpm
Module 6A............................... : 24A30001.rpm
Module 6B............................... : 24C7000B.rpm
Module 6E............................... : 3F980004.rpm
Module 70............................... : 04090001.rpm
Module 71............................... : 040A0001.rpm
Module 72............................... : 040B0020.rpm
Module 73............................... : 042B0008.rpm
Module 74............................... : 48AE0001.rpm
Module 75............................... : 48AF0001.rpm
Module 76............................... : 48B00001.rpm
Module 77............................... : 2E1C0001.rpm
Module 78............................... : 00090020.rpm
Module 79............................... : 48B10001.rpm
Module 7A............................... : A66C0001.rpm
Module 7B............................... : 04330008.rpm
Module 81............................... : 23A30100.rpm
Module 82............................... : 48B20002.rpm
Module 83............................... : 48B60004.rpm
Module 84............................... : 48BA0001.rpm
Module 85............................... : 48BB0001.rpm
Module 86............................... : 48BC000C.rpm
Module 87............................... : 48C80001.rpm
Module 88............................... : 48C90001.rpm
Module 89............................... : 48CA000C.rpm
Module 8A............................... : 48D60002.rpm
Module 8B............................... : 48D80002.rpm
Module 8C............................... : 2E1D0188.rpm
Module 8D............................... : 2FA50004.rpm
Module 8E............................... : 48DA0001.rpm
Module 8F............................... : 48DB0004.rpm
Module 90............................... : 2FA900A0.rpm
Module 92............................... : 3E5B0048.rpm
Module 93............................... : 043B0080.rpm
Module 94............................... : 053B0040.rpm
Module 96............................... : 130800A0.rpm
Module 97............................... : 12080100.rpm
Module 98............................... : 13A80360.rpm
Module 99............................... : 057B0002.rpm
Module 9A............................... : 057D0002.rpm
Module 9B............................... : 30490004.rpm
Module 9C............................... : 3EA30040.rpm
Module 9D............................... : 48DF0001.rpm
Module 9E............................... : 057F0002.rpm
Module 9F............................... : 48E00002.rpm
Module A0............................... : 3EE30064.rpm
Module A1............................... : 3F470003.rpm
Module A2............................... : 48E20002.rpm
Module A5............................... : 05810004.rpm
Module A6............................... : 05850002.rpm
Module A7............................... : 1AA80032.rpm
Module A9............................... : 3F500048.rpm
Module AA............................... : 304D0004.rpm
Module AB............................... : 48E40008.rpm
Module AC............................... : 30510008.rpm
Module AD............................... : 3F9C0529.rpm
Module AE............................... : 30590011.rpm
Module AF............................... : 0587000E.rpm
Module B0............................... : 306A0004.rpm
Module B1............................... : 306E0008.rpm
Module B2............................... : 44C50015.rpm
Module B6............................... : 3076000E.rpm
Module C0............................... : 30840003.rpm
Module C1............................... : 48EC0003.rpm
Module CB............................... : 46620030.rpm
Module CC............................... : 30870008.rpm
Module CF............................... : 05950002.rpm
Modules group reading
Into folder............................. : <HDD Profile>\Data\Groups\
00...................................... : 00080960.smd
01...................................... : 09681140.smd
02...................................... : 22DA12C0.smd
03...................................... : 359A125C.smd
04...................................... : 47F601F4.smd
05...................................... : 1AA80832.smd
06...................................... : 4A400960.smd
LDR file creation
Overlaes loading ...
Rom loading
LDR file saving
LDR file forming completed
Translator regeneration
P-List reading
SA P-List reading
P-List file saving
SA P-List file saving
P-List clearing
Maxtor techno command error. Command : 59. Code : 0119
Module recovery
Module recovery
Module recovery
Module recovery
P-List reading
SA P-List reading
P-List file saving
P-List clearing
Not access data...
PostPosted: November 27th, 2008, 14:43
before smart bad, now smart ok
PostPosted: November 27th, 2008, 20:33
nice post
PostPosted: November 28th, 2008, 13:59
arahamawan wrote:
nice post
He is looking for a solution !!!
PostPosted: December 1st, 2008, 9:01
HELP? :?: :?:
:mrgreen:
PostPosted: December 1st, 2008, 16:17
Please gurus look! Errors!!
:mrgreen:
LOG 6l080l0 2.txt [5.85 KiB]
Downloaded 834 times
SA SURFACE VERIFICACION.txt [6.73 KiB]
Downloaded 749 times
SA STRUCTURE TEST.txt [18.34 KiB]
Downloaded 887 times
PostPosted: December 2nd, 2008, 7:59
:mrgreen:
BAD MODULES 33, 93
FUNCTIONS MODULES? :mrgreen:
PostPosted: December 2nd, 2008, 9:40
Look.
Module : 22............................. : Ok
Module : 34............................. : Ok
UBA 1092 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 104453/3/324
UBA 1143 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104453/3/377
UBA 1144 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104453/3/377
UBA 1145 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104453/3/377
UBA 1152 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/2
UBA 1153 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 104454/3/1
UBA 1154 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 104454/3/2
UBA 1155 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/3
UBA 1156 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/4
UBA 1157 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/6
UBA 1158 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/6
UBA 1159 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/7
UBA 1160 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/8
UBA 1161 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/11
UBA 1162 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/11
UBA 1163 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/11
UBA 1164 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 104454/3/12
UBA 1165 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/14
UBA 1166 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/15
UBA 1167 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/15
UBA 1168 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/16
UBA 1169 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/17
UBA 1170 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 104454/3/18
UBA 1171 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/19
UBA 1173 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/22
UBA 1174 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 104454/3/22
UBA 1188 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/36
UBA 1191 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/41
UBA 1192 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 104454/3/41
UBA 1193 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 104454/3/41
UBA 1194 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 104454/3/42
Module : 93............................. : Error
Module : 7B............................. : Header
Module : 33............................. : Ok
Module : 37............................. : Ok
Module : 1F............................. : Ok
Module : 78............................. : Ok
Module : 18............................. : Ok
Module : 21............................. : Ok
Module : 1E............................. : Ok
Module : 1A............................. : Ok
Module : 2F............................. : Ok
Module : 30............................. : Ok
Module : 63............................. : Ok
Module : 48............................. : Ok
Module : 1D............................. : Ok
Module : 1B............................. : Ok
Module : 64............................. : Ok
Module : 5E............................. : Ok
Module : 70............................. : Ok
Module : 71............................. : Ok
Module : 72............................. : Ok
Module : 39............................. : Ok
Module : 38............................. : Ok
Module : 4F............................. : Ok
Module : A7............................. : Ok
I can rewrite I modulate it 93(DB) ? I find that not…
Users browsing this forum: No registered users and 17 guests
