 Post subject: WD PCB Compatibility Question
PostPosted: October 30th, 2008, 11:05
I've got a WD800JD-75MSA1 that is doing the standard western digital click and spin down. I have solved this issue a number of times with a PCB swap (with ROM of course) but this particular one is proving difficult to find the right PCB. The original PCB is 2060-701335-003 Rev B. All of the similar boards I have in the basement are 2060-701335-005 Rev A. This is the first time I've encountered a western digital PCB that is similar except for different last number and revision. The PCB swap with this board does not help, even after uploading the ROM.
Anyone have any experience with this? Would you expect the PCB to work fine, or do I need to keep looking for an -005 Rev A PCB?
Thanks for the input.
 Post subject: Re: WD PCB Compatibility Question
PostPosted: October 30th, 2008, 11:09
Yes, should work. Won't hurt for sure.
www.datarecoveryne.com
PostPosted: October 30th, 2008, 11:10
Yeah, I guess that the alternative if its not a PCB issue is a heads problem which means alignment problems and all of that not fun stuff...
PostPosted: October 30th, 2008, 11:17
It should be fairly easy to work on this drive.
Need help? I can help.
PostPosted: October 30th, 2008, 11:35
Would this not fall into the category of WDs where the heads lose alignment when you take the lid off?
PostPosted: October 30th, 2008, 11:37
Every drive has this issue.
PostPosted: October 30th, 2008, 14:52
U have to find
2060-701335-005 with the same controler
like in 2060-701335-003....
There are two types of pcb : 2060-701335-005
with the different type of controler....
Spasavanje podataka
PostPosted: November 2nd, 2008, 6:58
I have this pcb PM me .
Users browsing this forum: Google [Bot], WebClaw and 55 guests
