Forum rules
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Lacie Bigger disk
PostPosted: November 5th, 2008, 4:57
2 disk lacies use a standard RAID0 configuration, or occasionally a JBOD. 4 disk LAcies use a completely different configuration, these cannot be rebuild in winhex as winhex does not support the complex RAID mode required.
PostPosted: November 5th, 2008, 5:40
I just finished a rebuild of a LaCie 2x250gb drive in winhex with no problems.
That is fine - 2x drives mean It's a Lacie BIG disk. The original poster was talking about a Lacie BIGGER disks - these have 4 disks in a RAID configuration that is impossible to unscramble in WinHex.
<itch>
https://www.mjm.co.uk/
PostPosted: November 11th, 2008, 21:35
Gotcha. Haven't had one of those come across the desk yet.
PostPosted: November 12th, 2008, 4:22
I've done a couple of these Bigger disks before, as far as I remember the disks are in pairs of RAID 0, and then spanned.
Sean
PostPosted: November 14th, 2008, 6:31
dobrevjetser wrote:
Works almost allways with winhex or ufs-explorer.
Most difficult is stripe-size and start-sector.
Dobre
I have a solution, and it can not be built in Winhex unless I am missing something
PostPosted: November 14th, 2008, 14:07
I had that drive (LaCie Bigger 4x250GB) it turned out that config was RAID0 + JBOD
JBOD[Raid0(Disk1,Disk2),Raid0(Disk3,Disk4)]
Raid0 with 64KB block size
