 Post subject: MK4025GAS - PCB swap
PostPosted: November 12th, 2008, 7:16
Hi all,
I've a Toshiba MK4025 here with the PCB drained in orange juice. The microvias below the BGA chip are well corroded, so I'll give it a try with a PCB swap. Can anyone confirm whether swapping the serial flash (IC12) would suffice?
 Post subject: Re: MK4025GAS - PCB swap
PostPosted: November 12th, 2008, 7:50
I believe so. :wink:
PostPosted: November 12th, 2008, 10:21
You should swap it.
www.datarecoveryne.com
Users browsing this forum: Majestic-12 [Bot] and 231 guests
