Post new topic Reply to topic  [ 32 posts ]  Go to page 1, 2  Next
 Post subject: Seagate 7200.11 Error Code
PostPosted: October 17th, 2008, 9:40
Hi all,
Anyone help me with this 500Gb 7200.11 Seagate?
Terminal shows:
LED: 000000CC FAddr:024A051
I've no idea what this means, anyone shed any light on this?
Drive spins up and sounds like it calibrates, but stays BSY.
Thanks in advance.
Sean
 Post subject: Re: Seagate 7200.11 Error Code
PostPosted: October 17th, 2008, 11:08
Hi pcimage
This is the same message that is given if the PCB is not connected to the head / disk assy. So my guess is that if the spindle is running there is a problem with the heads or preamp. Don't know exactly what it means though. :cry:
PostPosted: November 3rd, 2008, 21:26
I've the same problem. :evil:
Did anybody fix the problem :?:
PostPosted: November 3rd, 2008, 23:35
firmware corruption.
PostPosted: November 4th, 2008, 6:42
I can repair
msn:fixhdd@msn.com
PostPosted: November 10th, 2008, 7:05
is it possible to restore information by replacing the flash memory chip from another hdd?
PostPosted: November 10th, 2008, 14:50
no the firmware is on the platters .
PostPosted: November 12th, 2008, 5:01
thats a head problem 100%
If the PCB is not connected to the HDA the heads cannot be found :idea:
change the heads or head
PostPosted: November 12th, 2008, 9:32
Thanks guru,
I'll check it once I get permission from client to open the drive.
Sean
PostPosted: November 12th, 2008, 11:00
Why do you need permission? Would a garrage phone you up to ask if they could 'look under the hood?"
That really gets on my nerves when clients complain their 'seals' are broken. Fair enough if we are talking mammals and I clubbed them to death, but no, we are talking a hard drive sent for an evaluation.
Sorry. Rant over.
PostPosted: November 12th, 2008, 13:47
Agree. We do almost never ask customers for permission either. All those external hard disks that come in nowadays have often head damage. One might kill the disk if letting it spin up before hda is inspected! Imho
Arthur
PostPosted: November 13th, 2008, 5:30
Normally I wouldn't, but this drive is very new,and this particular client is very fussy.
PostPosted: November 13th, 2008, 6:24
RANT:-
Plumber costs $1200 USD to install a combi boiler.. People are happy to pay for some cock to fit a bloody boiler BUT don't want to pay 5/6/700 USD for data recovery?!!!!!!!!!!!!!!!!!!!!!
All a plumber needs is a fking wrench!
I feel better now :O*
PostPosted: November 13th, 2008, 6:25
sometimes I want to stick their drive all the way up their A*se
PostPosted: November 13th, 2008, 6:50
pcimage wrote:
Thanks guru,
Sean
you allways got to ask the clients permission unless you give them the repair sheet
which tells them the drive will be open up for the second stage.
its called covering your own arse as sometime clients can be right muppets
PostPosted: November 13th, 2008, 11:40
no, it's not
PostPosted: November 13th, 2008, 11:53
What is it then? ;-)
PostPosted: November 13th, 2008, 12:01
SA
PostPosted: November 18th, 2008, 19:45
Doomer
Where is the read channel on the drive? :wink:
PostPosted: November 18th, 2008, 22:07
inside CPU
Users browsing this forum: ccc, pepe and 50 guests
