Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: Toshiba MK6025GAS - Need Advice
PostPosted: November 13th, 2008, 7:15
msurgeon wrote:
Toshibas are very tolerant of platter mis-alignment. You can move one 90 degrees and it will still work. However, if you still think alignment is an issue try moving the two platters relative to each other to see if it makes a difference. If you're sure the PCB is original then you can't do any harm at this point.
You tried this yet spaz?
PostPosted: November 13th, 2008, 11:12
I have found that most drives are quite tolerant to some misalignment. I have done some tests on drives and found some interesting things out. I am not going to share anything at this point because it is still all a work in progress.
What I would recommend is other people trying this sort of stuff out themselves and see what they find
The last I heard of God he was worshiping me
PostPosted: November 13th, 2008, 11:21
I havent had chance yet. Still waiting for client to approve the additional costs. May I recommed that when testing alignment issues, use disks with real data on. After you misalign platter, test files.
Users browsing this forum: Majestic-12 [Bot] and 63 guests
