 Post subject: File Repair on Jpegs
PostPosted: November 19th, 2008, 13:46
Can anyone tell me what the best software is for jpeg repair.
thanks
Simon
 Post subject: Re: File Repair on Jpegs
PostPosted: November 20th, 2008, 4:19
there not many programs that can total fix jpegs
are you getting draw line failed.
if so that because of the program compressing the file everytime its opened.
PostPosted: November 20th, 2008, 11:40
I've got thumbnails that are showing up but when I click on them they open different pictures. I also have a lot of files with thumbnails but when I click on this nothing comes up.
Simon
PostPosted: November 20th, 2008, 12:23
U should be check on first "headers" did u check it? wich was the problem on first from the hdd" formatted", " bad sectors" " bad heads"?
PostPosted: November 20th, 2008, 12:36
when copying files from a main pc drive to a external drive the copy process failed. From there the folders with all the pictures disappeared. I imaged the drive and used get data back and recovered all the pictures but many of them seem missing, damaged and misrepresented.
sime
PostPosted: November 20th, 2008, 13:14
Hi, sorry but its unclear to me which drive you are working on. Main pc or external?
Take a look at the files you have recovered so far. Check and compare the file sizes.
Are many files showing 0 bytes?
PostPosted: November 20th, 2008, 13:15
i'm running off the destination drive, not the new one. I used my ddi to do a complete clone of the drive. There are many files with 0 file size.
sime
PostPosted: November 21st, 2008, 3:54
Simon, can you clarify what went wrong and what you have done since?
From your description I understand you have since imaged your main pc hard disk to what was the external disk and you are now trying to recover files from the image?
Sorry but I can see 2 or 3 different scenarios here and it needs to be clear.
Recovering files of a 0 bytes size usually means they have been overwritten.
PostPosted: November 21st, 2008, 4:41
From the sounds of what's happening here, I would use something like "Recover My Files".
It searches for file signatures and then attempts to ressurrect the file structure, and with this software it give you a "running commentry" of all raw files recovered so far, and you can view them at a good size and evaluate their validity.
PostPosted: November 21st, 2008, 7:38
try this program out this might help you out
but it runs in dos
http://www.cgsecurity.org/wiki/PhotoRec
PostPosted: November 21st, 2008, 7:44
this is another program we use for repairing some jpeg files
your have to buy it but you can test your files before purchasing it
http://www.hketech.com/JPEG-recovery/index.php
Do you find that some photos recovered by digital photo recovery software are corrupted, e.g.:
Splits into two (or even more) parts, and
In between there is part of another photo, and
The color of the lower part(s) may be changed, and
There is a shift of the contents of the photo
if you dont want to buy the product yet send me one of the corrupt files
and i try and fix it for you
PostPosted: November 21st, 2008, 7:55
allso this program might help you if the files are corrupted
http://www.irfanview.com/
it supports most images and if it dedect image with wrong extention it ask if u want to rename.
PostPosted: November 21st, 2008, 21:28
thanks guys' very helpful, I'll do some downloading and testing.
sime
PostPosted: November 22nd, 2008, 2:56
how your getting on with the recovery did any of these programs help you out
whooops i spelt detect wrong allnight recovery work not much sleep :(
PostPosted: November 22nd, 2008, 11:31
I'm just doing recover my files right now. It looks like it'll be going for a day or two... stay tuned.
PostPosted: November 22nd, 2008, 17:02
I'm interested to know how well photorec works. I use that guys other software, TestDisk, fairly regularly.
