 Post subject: Official version of HD Doctor Utility for Seagate 7200.11 ha
PostPosted: November 26th, 2008, 3:30
Official version of HD Doctor Utility for Seagate 7200.11 hard drive has been released.
The 25th of November, 2008
HD Doctor for Seagate
Today we have announced the release of the Official Version of HD Docctor Utility for Seagate 7200.11 family hard drives which helps to solve the problems of: 1)HDD Status stays BUSY; 2)HDD being detected with 0 in LBA; 3)HDD reports SMART error on startup. All these problems now can be fixed without damaging the data (works for data recovery). Those will be the unique features which are only available in HD Doctor utility, no other similar tool is capable for solution before our release! We have been preparing to add these new capabilities into Data Compass as well, please keep an eye on our website for news.
We have already worked out the solution for bad sector repairing by adding them into the P-List; this feature for HDD repair only will be available in the next update.
Upgrade Log for HD Doctor for Seagate 3.0:
1. Upgrade of the support list to include Barracuda 7200.11 family.
Before the barracuda 7200.11 being added into the support list, in CMD mode, the utility outputs no log information or messy code if users connect a Barracuda 7200.11 drive. Now by installing the upgrade version, after choosing drive family as Barracuda 7200.1, the utility will automatically adjust the Baud rate so that users can receive the correct display in CMD mode.
2. Unique feature in the world to repair Barracuda 7200.11 detected with 0 GB.
The problem that LBA is detected as 0 is a typical malfunction for Barracuda 7200.11. Such drives can be detected normally but the data area is inaccessible with LBA detected as 0. The version 3.0 adds the feature to recover such malfunction without damaging the data on the drive.
3. Upgrade solution for Barracuda 7200.11 malfunction that drive stays BUSY. Please refer to the user manual for detailed operations.
4. Adds the feature to get rid of CE LOG error.
The feature is intended for Barracuda 7200.8, Barracuda 7200.9 and Barracuda 7200.10 drives. The malfunction drive can be ready and detected normally, but it will be very slow in reading data from the drive. When being connected to HD Doctor console, the CMD utility will repeatedly output CE Log error message, which is the reason that causes the drive being very slow in reading data from. The version 3.0 adds the feature of CE Log Repair to remove such malfunction.
HD Doctor for Seagate is a software-hardware complex designed for data recovery from damaged Seagate hard drives by SalvationDATA Technology, LLC. Its first release was on 2004, since then it was developed from a DOS program that supported the major models of Seagate drives to a software-hardware complex runs on Windows with easy and instandly renewable USB installation. Now it has been the tool supports the most comprehensive drive families; SalvationDATA is continuously working on new features that help users in solving newcome data recovery barrier. As the problems of Seagate Barracuda 7200.11 being exposed, on this July, SalvationDATA has worked out the solutions for three typical headaches mentioned above; our technician did a lot of tests inside and outside the lab with the help of some valuable customers. After the long test and improvement, today, as usual, we provide this unique feature as a free upgrade to all our customers.
Customers can download the upgrade version from the exclusive client forum directly.
If you forgot your username, please contact us.
SalvationDATA Forum :http://www.salvationdata.com/forum/
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
 Post subject: Re: Official version of HD Doctor Utility for Seagate 7200.11 ha
PostPosted: November 26th, 2008, 10:33
Good job SD
PostPosted: November 26th, 2008, 12:52
Hi Laura & Salvation Team,
Most expected update for Seagate 7200.11 drives.
This shows your continuous Research and Development.
Appreciate your team's effort.
-RDS.
PostPosted: November 29th, 2008, 2:25
yes good RE ... :)
PostPosted: November 29th, 2008, 23:19
Thank you SalvationData, your products upgrade always free, i will buy more tools from your company.
PostPosted: December 1st, 2008, 14:08
...and it works fine for Baracuda 11 cases, I used it today...and I hope that You will develop some similar solution for Baracuda ES.2
PostPosted: December 1st, 2008, 15:55
I assume last three posts were from SD workers :)
PostPosted: December 2nd, 2008, 6:30
:O) :lol: :heeey: Salvage Data :heeey:
PostPosted: December 2nd, 2008, 19:25
Wrong...I'm far, far away from China...and I'm a customer of SData...If I'm sattisfied with their free update, I can say that...whatever You think...
PostPosted: June 23rd, 2009, 4:37
Greetings,
How can I get that HD Doctor Utility for Seagate 7200.11? I have a
Seagate
Model: st31000340as
Firmware: SD15
Site Code: KRATSG
I turned on my computer and it was freezing. Removed the hdd and it loaded fine. I tried to attach it with a usb external kit but still wasnt found either in BIOS internally or Windows externally. Could that program possibly fix the problem? It spins up fine and no rattling.
PostPosted: June 23rd, 2009, 4:52
Buy it. Box + Sw.
PostPosted: June 23rd, 2009, 14:23
Yes it will fix the problem, but it's not just a software solution, there's a hardware piece of kit too.
I think Salvation only sell the HDD Doctors as a kit in the region of $2000.
Cheaper for you to send to a pro, where are you based?
PostPosted: June 23rd, 2009, 15:20
Plus you will need to know how to use it.
PostPosted: June 23rd, 2009, 15:46
Yep, the manuals aren't exactly all-encompassing either!!
PostPosted: June 23rd, 2009, 15:55
Thanks guys.
Im in Hawaii.
PostPosted: June 24th, 2009, 3:20
What? There's a manual? :lol:
PostPosted: June 24th, 2009, 16:25
I appreciate everyones replies/responses/ offers.
I decided to call Seagate once again after seeing all the problems with the firmware possibly causing the drive to not be recognized in the BIOS.
So I called back to Seagate and told them that I was unaware of the firmware that would cause this problem and did some research and found many people with Seagate drives had the same problem. The customer service rep said that not all the hard drives were affected but I can check to see if yours was. I waited anxiously for about 2 minutes. She came back and said that your hard drive was affected. We can send it out to i365 and they can flash your hard drive with a new firmware to hopefully remediate the problem.
Then they patched me over to i365 and began the process.
PostPosted: June 24th, 2009, 17:16
I'd like to modify my last post..
It was suggested from a member as to find out more information about that problem which resulted in me calling back to Seagate...
PostPosted: June 25th, 2009, 8:54
Wow! If i365 does it for free, it will be the first I've heard of this year.
Users browsing this forum: Bing [Bot], Google [Bot], napalm_atx and 52 guests
