Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: Seagate Terminal Commands? 7200.7 "Error Reading Reserve Tr
PostPosted: December 5th, 2008, 14:24
Just a quick reply : even if some people had details right from the manufacturer, other people have only made a lot of experiments and came to the same result. In any case, it's always the same story... "will this forum jeopardize our bread and butter" ?!?
PostPosted: December 5th, 2008, 18:15
If this help you :
Error Reading Reserve Track Defect List
"very probably the drive had some of his heads damaged or dirty
well , the heads cannot read the current cert code
It can happen the CERT is good - but the heads cannot load it ?"
ZeBong
" Россия еще раз"
PostPosted: December 6th, 2008, 8:40
7200.7 is known to suffer from dirty heads.
PostPosted: December 6th, 2008, 9:21
So I should use the terminal read commands to check each head?
Computer Dinosaur, servicing PC's since 1976 http://www.Computer-Help.Net
PostPosted: December 6th, 2008, 11:25
you'd be doing yourself a favor not to keep messing with the terminal. at this point everything you do decreases your chances of recovering your data.
PostPosted: December 7th, 2008, 11:33
It would be more better to post that at FUN Stuffs
!!!My drive SA broken, Should I Replace the SA from another drive!!!
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
Users browsing this forum: gameboybin, Kernelfergus and 97 guests
