 Post subject: PCB SWAP HTS541616J9SA00 160 GB
PostPosted: December 9th, 2008, 8:14
Hi to all!
To have one pcb compatible is enough to have the same numeration?
(220 0A28613 01)
Or it must possess plus an identical item? (chip)
:roll:
therefore I have hdds here of 120GB with pcb of same numeration... :mrgreen:
Нет ничего невозможного
 Post subject: Re: PCB SWAP HTS541616J9SA00 160 GB
PostPosted: December 9th, 2008, 9:30
Must match first two lines on label on PCB.
Also move NVRAM from patient to donor.
PostPosted: December 9th, 2008, 13:35
In my experience, simply matching the model and transferring nvram will work.
PostPosted: December 16th, 2008, 8:46
Thanks all replys!!
Problem solved!! :mrgreen:
:mrgreen:
PostPosted: March 11th, 2009, 13:07
Sempre
What was your problem?
Clicking sound and not loading correctly from the system?
I have it exactly hard disk with pcb 220 0A28613 01 and think that changing the pcb is possible to fix it
The syntoms are:
turn on hd
try to turn the platters
"clap clap clap" sound every two or three seconds
Wah do u think about it?
Kind regards,
Users browsing this forum: Google [Bot] and 68 guests
