 Post subject: Need Maxtor Module
PostPosted: December 12th, 2008, 18:07
Need just one module . . . RzTBL (module #78) for Maxtor 5A250J00802A1, which is a 250 GB Maxtor MaXLine II with Firmware RAMB1TU0
Thanks in advance.
http://www.datasaversllc.com
 Post subject: Re: Need Maxtor Module
PostPosted: December 12th, 2008, 18:11
Isn't that unique?
PostPosted: December 12th, 2008, 18:43
pcimage wrote:
Isn't that unique?
Not completely, but there is a lot of combinations....
Jono, don't you know a way to rebuild it from another list, log or module?
Both copy are bad, and you can't slipt + merge the copies?
Regards,
Janos
PostPosted: December 12th, 2008, 19:45
PM me with your email
www.datarecoveryne.com
PostPosted: December 13th, 2008, 10:38
pcimage wrote:
Isn't that unique?
Yes, it is an adaptive module.
PostPosted: December 13th, 2008, 10:40
N.C. wrote:
pcimage wrote:
Isn't that unique?
Regards,
Janos
This drive has module 93, which I believe contains the info.
I'm unfamiliar with the term slipt. I fixed the problem with the module, but it would be great to know another technique.
PostPosted: December 13th, 2008, 10:43
Thanks, everyone.
I seem to have resolved the module problem. All of the modules look fine except 7B (FW) and I get an error with Disk PW. The drive won't boot in regular mode (clicks), but will boot fine in safe mode.
Still working on it . . .
PostPosted: December 14th, 2008, 17:02
Let us know how you get on. You still need that module?
