 Post subject: WANTED!!!!!!!!! HDS728080PLAT20 Harddrive. URGENT!!!!!!!!!!
PostPosted: December 18th, 2008, 17:42
Hi all.
I´m looking for a Hitachi Harddrive:
Model HDS728080PLAT20
Revision 0A30362
It´s a 80 GB harddrive.
I need to recover all my family pictures from an old harddrive that had a "melt down".
Hope someone can help me. :)
 Post subject: Re: WANTED!!!!!!!!! HDS728080PLAT20 Harddrive. URGENT!!!!!!!!!!
PostPosted: December 18th, 2008, 18:36
What happened? What symptoms does it show? What tests did you run? Have you diagnosed the problem yet? How skilled are you? How important are the pictures?
PostPosted: December 19th, 2008, 6:30
What do you need. Heads or PCB?
PostPosted: December 20th, 2008, 10:31
The Dane wrote:
Hi all.
Revision 0A30362
What exactly do you intend doing with the donor drive?
PCB swap? It won't work. Specialist tools required for NVRAM manipulation.
Platter swap? Almost certainly unnecessary and 99.9% going to be unsuccessful.
Head swap? Do you have clean room and necessary tools and skills? Hitachi heads are particularly sensitive.
I suggest you find out exactly what the problem is.
Where are u based? Maybe we can point you in the right direction.
PostPosted: December 22nd, 2008, 16:58
Well as I wrote earlier it is burnt. When I connected it to the power surply, there came a small bit of smoke and then it just didnt work anymore. Tried to buy an eksternal harddrive "box" to see if it would work there, but without any luck. So I hoped that it might be possible to swap the cirkutbord from a doner harddrive to the old, to fix it. Had heard that some others had tried to do it with succes. Worth taking a chance I thought as it already is dead.
I´m living in Denmark, so if any of you knows anyone here, that is a guru at this, it would be much apriciated!!!
The pictures on the harddrive is VERY important to me, so I will do almost anything to get them back!!!!!!!
PostPosted: December 23rd, 2008, 1:52
Thanks for letting us know a 'melt down' means a burnt PCB.
If the pictures are that important, you should send your drive to a professional. Anything you attempt runs the risk of doing damage.
PostPosted: December 23rd, 2008, 6:59
Agree.
You will NOT be able to do a simple PCB swap on this particualar model. If it was a Maxtor DM9 or something like that, then yes we could advise you how to do it.
If you're willing to send the drive to UK, then I can help.
PM me if interested.
Sean
Users browsing this forum: No registered users and 87 guests
