 Post subject: HDD LLF problem -"Cannot change Visible in OnShow or On
PostPosted: July 5th, 2006, 12:37
Hi, I have problem with run of this program on Windows 2000 .
Installation is correct (....i downloaded some old versions too ) , but after run this program write - "Error Acessing Device: Bad function" and "Cannot change Visible in OnShow or OnHide" - After this i look only on clear page in program window . What be missing in my system ? ...
I have new installed Windows 2000 SP4 on two computers with same symptoms , under XP this program work correctly.
Any suggestion ??? , Thanks
 Post subject:
PostPosted: July 5th, 2006, 16:16
Maybe this program using some functions which are absent in Win2K?
 Post subject:
PostPosted: July 10th, 2006, 21:57
OK, now I found this thread, sorry ...
I just used FileMon while starting HDD LLF, and it shows that LLFTOOL.EXE is trying to open LLFTOOL.DEU, LLFTOOL.DEU.DLL, LLFTOOL.DE, LLFTOOL.DE.DLL in its directory, and then searching its own and the system directories for a uxtheme.dll, all of which are not found.
Is that uxtheme.dll the problem? I don't know why LLFTOOL would want to use that at all ...
MOW
 Post subject: Re: HDD LLF problem -"Cannot change Visible in OnShow o
PostPosted: August 1st, 2006, 13:39
Hello boys.. i'm new in this forum... i have same error on my PC...
After the error i can see a black page of program's and i can't select nothing.....
My Os it's Windows XP SP2... CPU Athlon XP 2400+ on Motherboard Asus A7v8x... Ram 512MB DDR 400Mhz.
I have 2 HD Matrox..... In Primary Master a Maxtor 6Y080L0 (This HD contains the Os.. Programs ecc. ecc.) and in Primary Slave a 6Y120L0..... i need to low format this HD...
Any Suggestion for me ??!
 Post subject:
PostPosted: August 2nd, 2006, 0:49
Site Admin
Hi
What version you are using?
 Post subject:
PostPosted: August 3rd, 2006, 6:53
admin wrote:
Hi
ops sorry... 2.36 build 1181.
 Post subject:
PostPosted: August 3rd, 2006, 11:41
Site Admin
Ok... Since this bug seems to appear not only on win2k PCs I will try to debug it. By the way what was the error message?
 Post subject:
PostPosted: August 3rd, 2006, 12:52
take any moment's...... i make some screenshot...
Edit:
I just start the program... the first error:
After Press "OK"... second error:
And Finally... The Empty Windows of the programs:
If you are need more information about my PC... please Ask Me.
 Post subject:
PostPosted: August 3rd, 2006, 14:06
Site Admin
Thanks for screenshots!
I will work on this on weekend.
 Post subject:
PostPosted: August 3rd, 2006, 14:07
Site Admin
By the way, do you have any USB or firewire devices connected? Maybe some flash readers, storage devices etc?
What about SCSI boards?
That might help :D
 Post subject:
PostPosted: August 4th, 2006, 22:56
That might help :D
no... my firewire it's unused...
actually i have some cable connect on usb port but then the respective devices are not connected... i have only a convertor for joy PS2 to PC and my Microsoft mouse....
 Post subject:
PostPosted: August 6th, 2006, 22:58
Site Admin
Ok, thanks for the info... Still cannot find the problem. Looking further...
 Post subject:
PostPosted: August 7th, 2006, 7:11
ok.. thanks...
 Post subject: Same thing
PostPosted: September 4th, 2006, 5:58
Hi I'm new in this forum, I have the same problem with Hard disk wipe tool 2.35 build 1178, on a laptop computer without usb disk or compact flash pcmcia conected.
regards,
claude
 Post subject: visible in onshow
PostPosted: June 20th, 2007, 17:32
The same happened on my machine and I was using it on a USB external drive, it started doing this problem when I had a USB hub connect and the external dive connected to it.
I am not sure why, but I hope this infomation could help
Regs.
 Post subject: Re: HDD LLF problem -"Cannot change Visible in OnShow or On
PostPosted: November 12th, 2008, 9:38
Hi guys,
Has there been any developments on getting this issue fixed? I've run into the same problem using both HDDWipe and HDD LLF, on a Windows 2000 SP4 system, no USB devices attached, one system IDE HDD, one SCSI HDD attached via PCI card.
Same error messages when opening either program:
- 'Error accessing device: Incorrect function'
- 'Cannot change Visible in OnShow or OnHide'
PostPosted: December 25th, 2008, 18:04
Same Problem here.
The Program ran once as it should - but after quitting and restarting or even deinstalling and reinstalling: no way, always that Problem!
PostPosted: December 25th, 2008, 18:21
Disk Wipe Tool has same problem!
PostPosted: August 27th, 2009, 19:03
Hey boys... on the same computer i have posted some reply ago....but now with the same XP Professional upgraded with Service Pack 3 this programs working without problems!
PostPosted: December 8th, 2010, 8:14
SOLUTION!
I can confirm that Disk Wipe and LLF were both generating this error message on my Dell E4300 (XP SP3) and IBM x60 (win7x86) - the E4300 has definitely been able to run LLF in the past.
EJECT THE SD CARDS
Job done :D
PC:C2Q Q6600@3.1Ghz|8Gb PC8500|4Tb|HD4870|G7|Razer Barracuda 5.1|win7-64
Server:Opt165@2.25Ghz|2Gb PC4000|7.5Tb|s2008-64
LaptopIBMx60|320Gb|4Gb|win7/Ubuntu10
Users browsing this forum: No registered users and 91 guests
