 Post subject: HELLO why care for thr firmware version when repale a WD
PostPosted: December 26th, 2008, 22:04
HELLO why care for thr firmware version when repale a WD hard drive head? i don't understand,anyone can explain it ?
 Post subject: Re: HELLO why care for thr firmware version when repale a WD
PostPosted: December 26th, 2008, 22:38
I don't understand your post - can you please explain it?
http://www.datasaversllc.com
PostPosted: December 26th, 2008, 22:54
i don't understand also :D
data recovery service[/b]
PostPosted: December 27th, 2008, 2:59
I think what Mr.Z Bond 007 was trying to say "Why firmware must be taken into account when finding a matching head"
The answer is you dont need to find an idential firmware in order to replace HDA.
PostPosted: December 27th, 2008, 8:50
Well, the head map are to be taken into account, if you want the drive to work. Or you can manually "remap the map" if you can :D Anyway the question is badly posted. Please ask again and tell what do you want to do.
PostPosted: December 28th, 2008, 0:51
Thanks all of your answer,I mean Why firmware must be taken into account when finding a matching head
What should think about when replacing a matching head,
same model number ?For Example: MODLE:WD800BB-55JKC0 ,same fifth and sixth DCM code?
anyone can explain it and it's reason?
Users browsing this forum: No registered users and 66 guests
