 Post subject: Clicking WD5000AAKS - 00MTA0
PostPosted: December 29th, 2008, 13:27
I've some trouble with the following drive:
Brand: Western Digital
Model: WD5000AAKS
Firmware: 00TMA0
The drive spins up, makes some clicks and restarts. The clicks are not very hard, but still it sounds like a head probleme. Now I am searching for a donor drive. If I have the drive I want to make sure to do take the correct steps.
First I though of swapping the PCB with the correct firmware version, but I read on the internet these drives have special calibration data in a chip. This data is unique. Swapping the PCB could cause in additonal damage to the drive. Can anyone answer the following questions:
> If the drive is not recognised by the bios, is this always a indication the PCB is broken? Or will this also happen with for example broken heads?
> Is it true you can not replace the PCB of these harddrives, due to special calibration data?
The next step will be opening the drive in a cleanroom. This will be my first time so first I want to practise a little bit on old drives. I checked this website with usefull information:
http://www.myharddrivedied.com/presentations/
If anybody have some more websites with information for replacing heads of a harddrive, please post it.
thanks
 Post subject: Re: Clicking WD5000AAKS - 00MTA0
PostPosted: December 29th, 2008, 17:43
Replacing the heads of a "hard drive" is simple.
Unless that "hard drive" is a Western Digital, when certain anomalies join the game.
Most "pro" companies don't enjoy working with these drives too much; I get the impression that you don't have 10+ years' experience in DR and mechanical repairs - so don't risk it.
Just my POV.
Duncan
PostPosted: December 29th, 2008, 18:19
I can post a video of myself .... but you're not me. If you see a video of Dr. Barnard doing a heart transplant, it doesn't mean tomorrow you can do the same :D
PostPosted: December 30th, 2008, 11:32
Thank you for your replies. In my country we have the saying that if you never tried it, you are sure it will not work. :D
I don't have the possibility for professional data recovery, so I will try it for myself. If someone still has some usefull hints, please let me know
PostPosted: December 31st, 2008, 23:16
means Your Data is not Important.. try Yourself and You will make thing worse and worse until unrecoverable, This is WD ( Worst Drive ) man..
Спасибо
СУТИОНО / АПИНГ
PostPosted: January 1st, 2009, 3:25
The net is full of bullsh... Er, suggestions. Try, 99,98% you'll destroy data and drive but if you don't try you'll never know. DON'T ASK US ANYTHING MORE and... Good luck.
Users browsing this forum: No registered users and 180 guests
