Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2  Next
 Post subject: Seagate 7200.11
PostPosted: December 24th, 2008, 6:33
Did any one know about problem with hdd Seagate 500 GB 7200.11 . I bought It for few day but now bios cann't detect my Harddisk / How can I get my data back or Where can I send my harddisk for recovery my data
 Post subject: Re: Seagate 7200.11
PostPosted: December 24th, 2008, 7:06
You will need to send this to a professional DR company in your area that can deal with the 7200.11 firmware problems.
<itch>
https://www.mjm.co.uk/
PostPosted: December 24th, 2008, 8:20
isn't that a firmware problem. If I change Circuit may be it work ?
PostPosted: December 24th, 2008, 8:27
NO !
PostPosted: December 24th, 2008, 12:22
Firmware is on the platters, not the PCB.
PostPosted: December 25th, 2008, 10:27
thank you very much , I 'll contact Data Recovery Company in our country first.
PostPosted: December 25th, 2008, 12:37
Where are u based on maybe we can guide to one hddguru near from u country not all companies on DR know the solution , and some times people who doesnt know tried "HDD Engineering" did "quicky" solutions like platter exchange´s , wich could be damaged the hope to did a DR after
Regards & Merry Christas
PostPosted: December 30th, 2008, 16:54
Hello Everyone!
I'm new to this forum so first of all HI. I also have a problem with this hell's creation - 7200.11. It's invisible on BIOS. I live in Poland and am lookig for someone nearby to help me with it. Thanks a lot in advance
Maciej
PostPosted: January 2nd, 2009, 17:14
Hello. I have the same type of HDD - Seagate 7200.11 500GB, the trouble is that now is blocked after a shock it took from a fall. I know that the HDD has this G-shock Force Protection System. Does anyone know about this system and how to unblock or reset it?
PostPosted: January 2nd, 2009, 17:25
Bestvex, your drive cannot withstand a fall from your desktop : seized motor and / or head stack damage. G-Shock protection system cannot avoid you to pay about 1000 $ and up if you want tour data back, otherwise live without data.... and drive (sad but true).
OR if you prefer.... only a professional can "reset" this.... system (in other words : open the drive in clean room, remove platters and/or remove seizure and/or replace headstack) and get your data back.
I think you are not really sure what you are talking about
These drives have free fall protection and G-shock servo compensation system
Free fall protection system can detect the drive is falling and park heads automatically - that's all it does.
G-shock servo compensation system trying to tune up servo system if drive experinced vibrations.
If you drive felt and now it doesn't spin it's 99% seized motor. There is no magic "unblock" procedure in this case. And for this model it very hard to make DR. What I'm trying to say - if it's seized motor - your data is gone
PostPosted: January 2nd, 2009, 18:16
Thanks for your reply Doomer, I really don't care too much about the data or the drive itself. Just trying to learn something and not to treat everything with ignorance.
PostPosted: January 13th, 2009, 23:43
My drive just bricked up as well after 2 weeks of running fine. Seems to be a pretty widespread problem with this model : Barracuda 7200.11 500Gb OEM. Undetected in Bios. MSFN forums is running a thread to track the problem I suggest you do drop by and lend support so Seagate will take notice.
http://www.msfn.org/board/index.php?showtopic=128514 - take a look at this.
PostPosted: January 14th, 2009, 2:48
Seagate knows and you can rma it. Forget data but you'll have drive replaced.
PostPosted: January 14th, 2009, 2:49
The most interested is the post #6 with the picture!
Almost all drive failed close to the 2008-12-24! :O
This is really interesting! :mrgreen:
Janos
PostPosted: January 14th, 2009, 3:37
Nightmare before X'mas maybe ? :D
My Forum
PostPosted: January 14th, 2009, 5:04
I would guess Seagate is aware of the problem through their i365 data recovery company, which is part of Seagate.
PostPosted: January 14th, 2009, 5:24
Are you saying you can't recover from this fault? Or are you saying he can't recover from this fault? Anyway I made a full recovery on on this exact same model with a seized motor a few weeks ago. 8)
Instead, I bet i365 is aware of the problem through Seagate. Malicious ? :mrgreen:
PostPosted: January 14th, 2009, 7:20
I agree, seized motors are pretty easy to recover data from...
Users browsing this forum: Google [Bot], Majestic-12 [Bot], michael chiklis, Stritom and 217 guests
