 Post subject: Anyone recognize this terminal error? U6 ST340810A
PostPosted: January 2nd, 2009, 6:59
Drive had a seized motor. Swapped motor with donor and now I get this error. Any help would be apreciated. Thanks.
Intf tsk rst 1024k x 16 buffer detected
Hd Msk 0A00 - Switch to full int.
Ready
ATRst
Err=001D
terminal.txt [122 Bytes]
Downloaded 897 times
 Post subject: Re: Anyone recognize this terminal error? U6 ST340810A
PostPosted: January 3rd, 2009, 8:58
Hi
If I'm not mistaken, that error means that is something wrong with module # 1D....maybe checksum or something else inside module.....
Rgds
www.datasave.ro
PostPosted: January 4th, 2009, 5:42
Ive tried with pc3kisa, pc3kpci, and SD Seagate but all refuse to read or write to the sa. Registers stay busy and then all lights out when any terminal command is given. After all registers go out drive stays spinning and is responsive to terminal. Doesnt make any horrible noises or have visual signs of a scratch. Even tried the donor pcb and heads but still the same symptoms. Anyone have any ideas before I assume platter damage? Thanks.
PostPosted: January 4th, 2009, 6:06
do u swap motor or swap platter. am affraid something like alignment problem
Спасибо
СУТИОНО / АПИНГ
PostPosted: January 4th, 2009, 6:14
I swapped the motor on this drive because it unscrews from the base. Its one platter so alignment isn't an issue.
PostPosted: January 4th, 2009, 6:18
Have you tried hotswap ?
My Forum
PostPosted: January 4th, 2009, 6:34
I was hoping it didn't come to that...
PostPosted: January 4th, 2009, 7:32
Yes, it's that
My Forum
PostPosted: January 5th, 2009, 9:11
Ready
ATRst
Err=001D
terminal.txt
did you ever get a good result on this? I am quite interested, I have never seen that kind of terminal output before...
Users browsing this forum: No registered users and 24 guests
