 Post subject: Seagate 7200.12
PostPosted: January 5th, 2009, 4:53
With the new year come and new things.
The new Barrcauda 7200.12 ST3500410AS 500Gb single platter.
http://img155.imageshack.us/img155/8775 ... 001ij4.jpg
Even Seagate did not know in their web site that this drive is released, but some reviews of new drive can already be found at http://skyline798.blog118.fc2.com/blog-entry-1266.html.
Lets hope they did not "solved" the problem LBA0 with some other strange LED xx problem..
DataRecovery.bg
 Post subject: Re: Seagate 7200.12
PostPosted: January 5th, 2009, 5:17
Thanks for 'info" Samo :D
My Forum
PostPosted: January 5th, 2009, 5:24
I wonder if they will sell after last years screw up. Personally i'm done using Seagate drives.
PostPosted: January 5th, 2009, 5:57
I hope that it had no problem than 7200.11
PostPosted: February 4th, 2009, 5:26
Here is it ;)
Rst 0x10M
(P) SATA Reset
PASS
RW: Error processing Performance Parameter File: 203C
No Phy: Staggered spin bypass
ASCII Diag mode
F3 T>
Package Version: PH0G2D.CCD3.BZ0E2H.CC34    , Package P/N: 100553103, Package Builder ID: AT,
Package Build Date: 01/02/2009, Package Build Time: 17:17:31, Package CFW Version: PH0G.CCD3.00135146.AT00,
Package SFW1 Version: D21A, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 01021717, CustomerRel: CC34, Changelist: 00135146, ProdType: PH0G.CCD3, Date: 01/02/2009, Time: 171731, UserId: 00236537
Servo FW Rev: D21A
RAP FW Implementation Key: 10, Format Rev: 0001, Contents Rev: A1 01 08 03
F3 T>
New Skews Pharaoh 0F with VTPI,RAP16,Common Code 3
Product FamilyId: 3F, MemberId: 05
HDA SN: 5VM0HFA7, RPM: 7201, Wedges: 120, Heads: 2, Lbas: 3A386030, PreampType: 59 21
PCBA SN: 0000M9266ELK, Controller: YETIST_3_0(649A)(3-12-3-2), Channel: AGERE_COPPERHEAD_LITE, PowerAsic: MCKINLEY DESKTOP LITE Rev 13, BufferBytes: 1000000
Servo FW Rev: D21A
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled
- LTTC-UDR2 compiled off /2
User Partition
LBAs 00000000-3A38602F
PBAs 00000000-3A609832
HdSkew 006E, CylSkew 002D
ZonesPerHd 11
Head 0, PhyCyls 000000-03C47E, LogCyls 000000-03C14E
     Physical      Logical       Sec   Sym   Sym      Data
  Zn Cylinders     Cylinders     Track Wedge Track    Rate
  00 000000-003B2D 000000-003B2D 0A3C  1211  001486E0 1695.000
  01 003B2E-006B07 003B2E-006B07 0A03  11AE  00141780 1659.375
  02 006B08-00AB57 006B08-00AB57 09A0  10FA  00134D00 1593.750
  03 00AB58-00E527 00AB58-00E527 0960 1083  0012C720 1550.625
  04 00E528-0130DB 00E528-0130DB 08D6  0F9B  0011C100 1466.250
  05 0130DC-01640E 0130DC-01640E 08A0  0F29  001140C0 1425.000
  06 01640F-01ACC6 01640F-01ACC6 0870  0ED6  0010E480 1395.000
  07 01ACC7-01F95A 01ACC7-01F95A 0819  0E4A  00104700 1344.375
  08 01F95B-023922 01F95B-023922 07BC  0DA0  000F87C0 1282.500
  09 023923-026A68 023923-026A68 0798  0D5C  000F3C60 1258.125
  0A 026A69-02A4CA 026A69-02A4CA 0733  0CA8  000E70C0 1192.500
  0B 02A4CB-02D382 02A4CB-02D382 0716  0C7D  000E4180 1177.500
  0C 02D383-0307E3 02D383-0307E3 06C0  0BC8  000D75E0 1111.875
  0D 0307E4-033F23 0307E4-033F23 066D  0B52  000CF120 1068.750
  0E 033F24-036E43 033F24-036E43 061B  0AC1  000C4E00 1016.250
  0F 036E44-03A06F 036E44-03A06F 05B8  0A12  000B8800  952.500
  10 03A070-03C47E 03A070-03C47E 0576  099B  000B0220  909.375
Head 1, PhyCyls 000000-03AD26, LogCyls 000000-03AA06
  00 000000-0039FE 000000-0039FE 0990  10D3  00131DC0 1578.750
  01 0039FF-0068E3 0039FF-0068E3 0973  109F  0012E460 1560.000
  02 0068E4-00A933 0068E4-00A933 0900  0FBD  0011E3E0 1477.500
  03 00A934-00E1DB 00A934-00E1DB 08E5  0FB1  0011D8A0 1473.750
  04 00E1DC-012A97 00E1DC-012A97 0880  0EF9  00110760 1406.250
  05 012A98-015CC9 012A98-015CC9 088C  0F0B  00111DE0 1413.750
  06 015CCA-01A2B5 015CCA-01A2B5 0840  0E84  00108720 1365.000
  07 01A2B6-01EDD0 01A2B6-01EDD0 07E0  0DC5  000FB040 1295.625
  08 01EDD1-022C5E 01EDD1-022C5E 0798  0D58  000F35A0 1256.250
  09 022C5F-025BC8 022C5F-025BC8 076C  0D0F  000EE4A0 1230.000
  0A 025BC9-0293F6 025BC9-0293F6 0733  0CA8  000E70C0 1192.500
  0B 0293F7-02C1C8 0293F7-02C1C8 0708  0C5E  000E1EA0 1166.250
  0C 02C1C9-02F42F 02C1C9-02F42F 06A0  0BAA  000D5300 1100.625
  0D 02F430-032A5F 02F430-032A5F 064C  0B1A  000CB100 1048.125
  0E 032A60-035897 032A60-035897 05F2  0A7A  000BFD00  990.000
  0F 035898-0389CC 035898-0389CC 0580  09B1  000B19C0  916.875
  10 0389CD-03AD26 0389CD-03AD26 0540 0931  000A88A0  870.000
System Partition
LBAs 00000000-000BAF4F
PBAs 00000000-000BBD9F
HdSkew 006E, CylSkew 0018
ZonesPerHd 02
Head 0, PhyCyls 03C47F-03C5D2, LogCyls 000000-000152
  00 03C47F-03C528 000000-0000A9 0394  063D  00072AE0  592.500
  01 03C529-03C5D2 0000AA-000153 0394  063D  00072AE0  592.500
Head 1, PhyCyls 03AD27-03AF1A, LogCyls 000000-0001F2
  00 03AD27-03AE20 000000-0000F9 0394  063D  00072AE0  592.500
  01 03AE21-03AF1A 0000FA-0001F3 0394  063D  00072AE0  592.500
DataRecovery.bg
PostPosted: February 4th, 2009, 5:58
Well...well...well...... :wink:
My Forum
Users browsing this forum: No registered users and 92 guests
