 Post subject: how to store good HDA's properly
PostPosted: November 18th, 2008, 20:22
I have been accumulating more and more good HDA's from recoveries, dead drives, spares, etc...
I currently put a peace of plastic between the heads and then carefully store them in a anti static bag. I am looking for a better way of storing them and wanted to know what other people are doing.
 Post subject: Re: how to store good HDA's properly
PostPosted: November 18th, 2008, 21:52
we normal store ours in a plastic case and use ESD BOX not static bags
as the piece of plastic might just fall out of the head
number each bag and when we need the headstack we get them out
when needed.
computer data base of what headstack we got in stock and logic boards.
store in a cool dry place.
PostPosted: November 18th, 2008, 22:00
Craig, that's exactly why I was looking for a better solution. The ESD box sounds good. I will look into it.
P.S. I am in the process of coding a Inventory database in SQL and VB as we speak :mrgreen:
Thanks!
PostPosted: November 19th, 2008, 10:54
I use little ESD boxes and seperate the heads with little rubber wedges cut from an eraser. Less likely to fall out.
Sean
PostPosted: November 19th, 2008, 16:14
What is an ESD box? Similar to a Seashell clear box you get with Seagate drives?
Any link to a site i can buy some of these ESD boxes you refer to?
PostPosted: November 20th, 2008, 4:10
esd stands for Electro Static Discharge
so the headstack unit dont get damaged by static
esd boxes check out ebay
for some good deals
PostPosted: November 20th, 2008, 4:13
here some companys that sell these type of boxes
http://www.esdproduct.com/ESD_Bins_Boxes.php
if you work with hard drives a lot o would get a esd mat
which we use all the time.
PostPosted: December 3rd, 2008, 15:20
Surely the safest way to store the heads are inside a sealed HDD? It takes a bit longer to take them out but at least they are protected. Thats what I use. All donor disks are stored in an inventry database which logs all the different HDD details.
PostPosted: December 29th, 2008, 9:32
Similar thing with my storage. :)
PostPosted: January 5th, 2009, 5:10
Best way to do it, I believe.
PostPosted: January 5th, 2009, 8:51
Looks like HDD Spaz is not such a spaz after all :D lol
PostPosted: January 5th, 2009, 9:01
To be honest, its more of a physical disability. I'm all tongue and wrists but my brain is good. :lol:
PostPosted: January 5th, 2009, 9:36
All tongue and wrists? How does that work for head replacement? :D
PostPosted: January 5th, 2009, 10:26
I would like to point out I always wear a mask to prevent dribbling on the platters.
PostPosted: January 5th, 2009, 16:37
:mrgreen: :mrgreen: :mrgreen:
