 Post subject: WD800JD PCB GOOD
PostPosted: January 5th, 2009, 14:03
Hi to all!
WD800JD clicking , PCB 100% OK
How I can have certainty that really the problem is heads or fw? :?:
:mrgreen:
Нет ничего невозможного
 Post subject: Re: WD800JD PCB GOOD
PostPosted: January 5th, 2009, 14:30
How many clicks are?
PostPosted: January 5th, 2009, 15:12
(03) three only,off :mrgreen:
PostPosted: January 5th, 2009, 18:06
Try your board on a similar drive.
Test heads one by one.
www.datarecoveryne.com
PostPosted: January 5th, 2009, 20:03
Check pm
PostPosted: January 6th, 2009, 7:59
Hi harddrivespecialist!!
It has as to verify heads with pc3kpci 2,21 or 2.27? :mrgreen:
Thanks!
PostPosted: January 6th, 2009, 8:06
beto wrote:
Check pm
Yes! check your PM!! REPLYS!
Thanks my Friend!! :mrgreen:
PostPosted: January 6th, 2009, 16:08
Hi to all! :mrgreen:
In the site hddguru says for a giver of heads needs to be:
" Exactly fw + In the alphabetic DCM code the sixth (and quite desirably the fifth) characters must be identical"
With its experience in this model WD800JD where can I help?
PostPosted: January 6th, 2009, 19:17
In my experience, that info applies to old WD drives and probably isn't reliable for the WD800JD.
Actually, for most WD 2 head drives, I've found it easy to get a compatible match, even when using other model numbers for donors.
http://www.datasaversllc.com
PostPosted: January 7th, 2009, 2:08
If you have SD or PC3k, do a hotswap using a decent donor, then try to read the modules(double-click in SD doctor). If you see data on some of the modules, head is ok. If not, head is blown. Also, try to view user area after hotswap.
Good luck.
A
PostPosted: January 7th, 2009, 6:06
Ok, thanks all replys!! :mrgreen:
PostPosted: January 7th, 2009, 6:08
It can be problem only with the alignment of heads? :?:
Users browsing this forum: No registered users and 70 guests
