 Post subject: WD5000AAVS - Head change
PostPosted: January 2nd, 2009, 11:52
Have change the head in this WD, but now i have the disk give DRD / DSC but dont have any info about the disk the model, serial, FW, size ?
PATIENT : WD5000AAVS-00ZTB0
DCM: HHRNNTJAHB
I just could find this model for head change:
DONNOR: WD5000AAVS-32ZTB0
DCM: HBNCHT2CH
Is any other problem here that i dont see ?
ZeBong
ZeBong
" Россия еще раз"
 Post subject: Re: WD5000AAVS - Head change
PostPosted: January 2nd, 2009, 12:12
ZeBong
Yes. :)
(if i think right, more than one...)
I can recover for you, if you need....
Regars,
Janos
PostPosted: January 3rd, 2009, 5:30
DCM: HHRNNTJAHB
DCM: HBNCHT2CH
ZeBong
Translator ?
My Forum
PostPosted: January 3rd, 2009, 7:17
yes HDA does not match
PostPosted: January 5th, 2009, 7:30
Are you referring to DCM code?
PostPosted: January 6th, 2009, 12:30
It seems that some strings of DCM should match.
PostPosted: January 6th, 2009, 12:50
Hi, wich ones ?
Jose
ZeBong
" Россия еще раз"
PostPosted: January 6th, 2009, 15:15
I believe it is 5th and 6th.....
PostPosted: January 6th, 2009, 15:17
yes
PostPosted: January 6th, 2009, 18:43
pcimage wrote:
yes
So in here just the 6th match
DCM: HHRNNTJAHB
DCM: HBNCHT2CH
So i get the DRD / DSC, but dont get the ID off the disk, in this case have to find other donnor.
ZeBong
ZeBong
" Россия еще раз"
PostPosted: February 28th, 2009, 18:26
Salvation say´s this:
WD Head Change:
Model
The first 3 digits of DCM
Motor Number
ZeBong
" Россия еще раз"
PostPosted: March 2nd, 2009, 14:23
WD Head Change:
Model
Motor Number
DCM is SHIT!
Forgot about it!!
You sould check head map!
Head maps must be same.
This user was found to be affiliated with Ace Lab/PC-3000. See this topic for details.
PostPosted: March 2nd, 2009, 14:30
Creator wrote:
WD Head Change:
Model
Motor Number
DCM is SHIT!
Forgot about it!!
:lol:
Learn :D
ZeBong
" Россия еще раз"
PostPosted: March 25th, 2009, 18:47
Aligment problem !!!
DRD / DSC ok , no ID off the disk.
ZeBong
" Россия еще раз"
PostPosted: March 25th, 2009, 19:13
"No! No different! Only different in your mind. You must unlearn what you have learned."
PostPosted: March 26th, 2009, 6:59
Confused ... :?
What are you saying please PM me.
ZeBong
ZeBong
" Россия еще раз"
PostPosted: March 27th, 2009, 15:58
Have unlearn everything about WD.
ZeBong
" Россия еще раз"
PostPosted: March 27th, 2009, 16:20
Unlearn everything that Salvation provides for a requirement.
www.datarecoveryne.com
PostPosted: April 1st, 2009, 7:03
harddrivespecialist wrote:
Unlearn everything that Salvation provides for a requirement.[/quote]
I agree.
