 Post subject: IDEAL DONOR HEADS HITACHI
PostPosted: January 6th, 2009, 10:04
Hi to all!!
HEADS bads model HTS541616J9SA00
in the site of hddguru one sends regards:
Hitachi 2.5' PCB revision match is mandatory + contry made
With its experience and that it recommends? :?:
Нет ничего невозможного
 Post subject: Re: IDEAL DONOR HEADS HITACHI
PostPosted: January 6th, 2009, 11:09
Tovarish,
In my experience, if you match the country and MLC code on this series you will be OK.
Some are DA1905 and others may be DA1712.
Jono
http://www.datasaversllc.com
PostPosted: January 6th, 2009, 15:19
How important really is the MLC and country to match? I have replaced defective heads with parts that matched model alone and has been successful.
Maybe I am just lucky?? :wink:
PostPosted: January 6th, 2009, 15:55
Hi hddguy! :mrgreen:
its experience was with the same model of this post? (HTS541616J9SA00) :?:
:idea:
PostPosted: January 6th, 2009, 16:05
Yes.
Part was purchased for a specific client, client decided he did not want to proceed, so parts were used on a different clients disk, same model different MLC and country, all data recovered :D
Maybe anyone else has similar experiences?
PostPosted: January 6th, 2009, 16:15
hddguy wrote:
Yes.
Thanks for reply! :mrgreen:
somebody has more similar experiences? :?:
PostPosted: January 6th, 2009, 16:44
Yes, have had success without matching MLC code.
PostPosted: January 6th, 2009, 19:13
I don't think country code is very important with this series.
But I have found, for example, that some 120 GB drives have 4 heads and others have 3. The MLC codes are different, but the model numbers are the same. You could have a situation where a 4 head Hitachi couldn't be read by a 3 head donor. That's why I suggest matching MLC codes to be on the safe side . . .
Jono
PostPosted: January 6th, 2009, 22:08
I had one recently where two drives with same MLC and same number of heads were different size... 80GB and 100GB respectively. I thought maybe the size was artificially limited so tried swapping them anyway, did not work.
PostPosted: January 6th, 2009, 22:38
Jono
Just had this problem, same model and different MLC with 3 heads, donor 4 heads. I noticed Apple branded drives have 3 heads. Weird...
PostPosted: January 6th, 2009, 23:55
Apple drives can have EITHER 3 or 4 heads . . .
PostPosted: January 7th, 2009, 2:00
HTS541616 ALL I see is have 4 head... easy to swap.
HTS541612 got 3 mdel of head. 012,123, n 1234.. not so difficult to swap head too.
I have test many time.
since it is still HTS... come from Apple and Standard PC... it is just the same manufacturer..
So what is the different....
Спасибо
СУТИОНО / АПИНГ
PostPosted: January 7th, 2009, 4:42
I have seen many occasions that a disk with same model, part no and mlc have different amount of heads. I needed to change heads on a 60GB travelstar, which had 4 heads, 3 donor drives purchased all with 3 heads. In the end I had to purchase a 80 GB donor drive because I knew it had the 4 heads. It worked though.
PostPosted: January 7th, 2009, 5:53
Jono
Yes, I have here of 120gb with 4 heads!
Thanks for reply!!
PostPosted: January 7th, 2009, 5:59
So I guess I was partially right! MLC is not for compatibiltiy, but for Head Map.
Thanks prodata :D
PostPosted: January 7th, 2009, 6:01
Very interesting its experience! :!:
PostPosted: January 7th, 2009, 6:03
Thanks all Replys!! :mrgreen:
PostPosted: January 7th, 2009, 7:31
Hi to all!! :mrgreen:
Exists some possibility of a model HTS541612 of 120gb with 4 Heads to be a donor for one hitachi (HT541616) of 160gb? Somebody already tried here? :?:
PostPosted: January 7th, 2009, 7:52
I think if family is same (HTS54) and heads number is same, then should be OK.
PostPosted: January 7th, 2009, 7:56
only one way to find out. report your findings.
Users browsing this forum: Google [Bot] and 334 guests
