 Post subject: Seagate Momentus ST9120821AS 120GB scratched platters.
PostPosted: January 7th, 2009, 4:46
Hi guys
Seagate Momentus 120GB with scratched platter.
The scratches are close to the inside edge on the top platter.
I was thinking of trying an enlarged rubber stop or something similar to stop heads reaching the scratched area?
My question is, has anyone had a similar case & been successful recovering data using this method?
I'd like to avoid destroying another set of heads.
Any thoughts?
Cheers
Ed
 Post subject: Re: Seagate Momentus ST9120821AS 120GB scratched platters.
PostPosted: January 7th, 2009, 4:52
the theory sounds ok, but I can not seem to view the image you uploaded....
PostPosted: January 7th, 2009, 4:55
neither do i.
Dobre
Murphy was an optimist
PostPosted: January 7th, 2009, 5:13
Just out of curiosity, is it from a apple with fw code of 7.01?
PostPosted: January 7th, 2009, 5:16
No it's not out of an apple.
FW: 3.06
Sitecode WU
PostPosted: January 7th, 2009, 5:33
i did recover some data like you described from such damaged disks.
It is essential the head cannot reach the damaged area.
However, it is very probable the head will fail soon again due to microscopic damages or that modules are not readable.
Dobre
PostPosted: January 7th, 2009, 5:38
I agree. On many occasions heads can be damaged by damage that you can NOT see. But as data is important to client, you can try head replacement. You will be no worse off if fails, and are in a win win situation by trying. Also, would be good to hear how well it goes for you
PostPosted: January 7th, 2009, 5:50
I work with someone that tried this on a maxtor with platter damage in the centre where the heads parked he managed to get a couple of GB of the drive before the heads died could be worth a try but try to know what you want to go in for.
PostPosted: January 7th, 2009, 6:02
I agree. Knowing what data is of more importance makes a huge difference.
PostPosted: January 7th, 2009, 6:22
After the exchange of heads, can be tried before making the image one copies direct of the files using DATA EXTRACTOR, mainly will be few files of more importance for recovery...
Нет ничего невозможного
Users browsing this forum: No registered users and 94 guests
