 Post subject: Samsung SP2504C w/ terminal log
PostPosted: January 13th, 2009, 17:29
Hi folks,
I have a Samsung SP2504C that spins up, makes a series of about ten faint seek sounds, then sounds normal. In MHDD it is busy while making the seek sounds, then goes ready, but any attempt to do anything to the drive causes busy to light and stay lit.
Here is the terminal log:
SPW 0000 NoLk
                  lltst 0000
                            SpnOk
spd:  0000 0000 0000
H: +00000
ADC: 0003
DAC: 888D
SK C: 00018B73
ENG>SRV>
  SvoTbl Loaded
  BD
  FdtTbl Loaded
????????????Sb
              WriteSctLog -- buffer not valid
And here is the terminal log from a functional SP2504C:
SPW 0000 NoLk
              lltst 0000
                        SpnOk
spd:  0000 0000 0000
H: +00000
ADC: 0000
DAC: 928D
SK C: 00018868
ENG>SRV>
  SvoTbl Loaded
  BD
  FdtTbl Loaded
ENG>
Any thoughts?
 Post subject: Re: Samsung SP2504C w/ terminal log
PostPosted: January 13th, 2009, 17:54
Check the MC. Smart or some log invalid / trashed? Check carefully the error lists and translator. Last: check the other mods.
PostPosted: January 13th, 2009, 18:19
The fun part is that Salvation has not released their Samsung module yet and I don't have a PC3K. :roll:
PostPosted: January 14th, 2009, 2:52
That's why I have custom solutions...
PostPosted: January 14th, 2009, 3:07
You don't need either... :mrgreen:
BTW, something looks suspected with PCB....have you tried replacing it?
I just hate spammers...It was a Spammer, who ruined my life!
PostPosted: January 14th, 2009, 10:57
Yep, that was the first thing I tried. Other drive works fine with either, this drive doesn't work with either.
Seems like I could get the job done with terminal commands, but references for samsung commands seem difficult to come by. PMs are always welcome. :mrgreen:
PostPosted: January 14th, 2009, 12:01
No term command will help, it's not seagate. Unless you want to send the mc sector by sector...
PostPosted: January 14th, 2009, 13:00
Any suggestions then, before I write this off as not-doable-by-me?
PostPosted: January 14th, 2009, 14:45
PostPosted: January 14th, 2009, 17:05
Should it be read, "Period"?
Users browsing this forum: No registered users and 270 guests
