 Post subject: HDS728080PLAT20 firmware trouble
PostPosted: January 15th, 2009, 13:05
I have a hitachi as mensioned above and it has firmware trouble. It clicks once then comes read but track 0 is not found. on PC-3000 it says that the module SRST is damaged. I have managed to get hold of the module but it fails to write to the damaged drive. Has anyone had this problem. What criteria do i have to match to be able to fix the module from a donor drive. Thank you all in advance
 Post subject: Re: HDS728080PLAT20 firmware trouble
PostPosted: January 15th, 2009, 13:12
What do u need DR or repair it?
PostPosted: January 15th, 2009, 13:13
I just need to recover the data
PostPosted: January 15th, 2009, 13:21
Could be usefull u can post u here the complete SA scan
PostPosted: January 15th, 2009, 13:30
here is the error report
File comment: Error log from pc-3000
141342.log [10.16 KiB]
Downloaded 641 times
PostPosted: January 15th, 2009, 13:37
On the SA scan shows its loading Opend Modules, and Zone tables, and adaptive modules its reading so u can tried to link to "another utility" and got data , :wink:
PostPosted: January 16th, 2009, 9:33
It says that the utility does not support this action :(
Users browsing this forum: No registered users and 109 guests
