 Post subject: Fujitsu Terminal Settings
PostPosted: January 15th, 2009, 15:34
Does anyone know the Terminal settings for Fujitsu MHV...AH drives ... Pc3000 says, connect to terminal, but I dont know the correct settings.
<itch>
https://www.mjm.co.uk/
 Post subject: Re: Fujitsu Terminal Settings
PostPosted: January 15th, 2009, 15:46
for AH it might not work
but anyway it's 19200, Even, 7 bits
and Fujitsu don't have commands echo
PostPosted: January 15th, 2009, 16:16
Thanks doomer - Do you know the pinout for PC3000 laptop adapter ?
I can connect wires directly if necessary ..
<itch>
PostPosted: January 15th, 2009, 18:30
No, sorry
I don't use PC3K adapter
PostPosted: January 16th, 2009, 4:13
Thanks though doomer, your help is appreciated ..
I dont suppose you know the TX, RX, GND pins on
Top of Drive
Circuit board
<itch>
PostPosted: January 16th, 2009, 5:03
Hi
->::<- the last 2 vertical pins...upper RX and below TX.
Rgds
www.datasave.ro
PostPosted: January 16th, 2009, 5:13
Thanks ccc and Doomer :)
<itch>
Users browsing this forum: Google [Bot] and 95 guests
