 Post subject: Seagate Baracuda ST3320620A burned element
PostPosted: January 18th, 2009, 19:10
Yesterday went home and attached external HDD to power, but no effect, just a smell.. I examined the power suply, found a gap, opened it and found 3 elements cutted of by radiator, that's grounded. So, i attached the HDD to PC, pressed ON button, no effect. turned just the PC's power suply on mannually, after attaching just HDD, no effect. Turned on Power suply and attaced the HDD, the power turned off. By examining the HDD, found a small gap in a black square form element with two legs, close to power input, that connects ground other plate.
So my question is, if there's a hope to bring the HDD back to life by my self and your help? Is it possible to find matching plate and replace with it?
S/N: 9QF5ZVM4
ST33020620A
P/N: 9BJ04G - 305
FIRMWARE: 3.AAE
DATECODE: 08016
SITE CODE: TK
Product of Thailand
There are a lots of Photos, that ments me a lot and need to rescue them!
 Post subject: Re: Seagate Baracuda ST3320620A burned element
PostPosted: January 18th, 2009, 19:15
Remove this element, just snip it off.
Your drive will almost certainly work again long enough to get data off.
Then throw it away, don't trust it again.
PostPosted: January 18th, 2009, 19:18
Sure?
A quite big element, about 5x2mm. Is this a resistor? maybe need to put a wire in its place?
Sorry for my english!
PostPosted: January 18th, 2009, 19:20
Search the forum for TVS, you'll find plenty of info about it.
PostPosted: January 18th, 2009, 19:31
It spinns! TNX! Now Need a fast Data recovery!
PostPosted: January 18th, 2009, 19:54
How should I operate with hdd? Use it slowwly (turn off for a while) or use it in a cold place? What are the recomendations? Now i can access the data, backing up some primary data!
PostPosted: January 18th, 2009, 20:23
can you post PIC?
data recovery service[/b]
PostPosted: January 18th, 2009, 20:40
networkpc3000 wrote:
can you post PIC?
Sorry, bad quality.. tomorrow will be better..
I circled the place, where was this element..
PostPosted: January 18th, 2009, 20:53
That was it..
All data I needed were saved to a safe place..
The HDD disapeared from My Computer, I turned it OFF, then ON and blue smokes came of the HDD.. So it's officially dead, but lucky saved the data! TNX again! :mrgreen:
PostPosted: January 18th, 2009, 22:25
That component protects the rest of the PCB from excessive voltage... I might start to be concerned about your power supply.
The drive works fine without it, but you could think of it as similar to a fuse. The fact that whatever blew the TVS then blew the PCB indicates to me that you have a power problem.
PostPosted: January 19th, 2009, 4:38
Ok, I'll take a serious test of power suply!
PostPosted: January 19th, 2009, 15:07
Glad it worked out for you!
Agree with drccsc, sounds like you have a dodgy/poor quality PSU.
Users browsing this forum: No registered users and 119 guests
