 Post subject: WD2000JS damaged ROM any hope?
PostPosted: January 20th, 2009, 2:02
Hi Guys
I have WD2000JS-00MHB0 with faulty ROM (ATMEL 25F1024AN), hard knocking/clicking then stop, it gives alias "HAWK" . Howswap checked all heads ok.
Swap pcb and ROM, same symptoms.
Any hope?
thank's for any inputs.
 Post subject: Re: WD2000JS damaged ROM any hope?
PostPosted: January 20th, 2009, 2:27
it is possible to get data without Original ROM.
Need SA modification....
Спасибо
СУТИОНО / АПИНГ
PostPosted: January 20th, 2009, 2:58
Спасибо
СУТИОНО / АПИНГ
PostPosted: January 20th, 2009, 5:17
I believe within UDMA PC3K you need to connect HDD in Kernel Mode, start utility in Kernel, and there is a option for searching for ROM copy in SA. It requires to be started from a loader so you need to have suitable fw in your database.
Never tried this myself yet, let us know if it works for you.
PostPosted: January 20th, 2009, 12:31
TerraNova wrote:
Hi Guys
Any hope?
are You sure rom i bad?
it looks lik heads to me
HddSurgery - Professional Data Recovery Tools
PostPosted: January 21st, 2009, 4:04
hddguy wrote:
...and there is a option for searching for ROM copy in SA...
ROM copy in SA is present only in ROYL families (with ROM bigger than 128kB)
Mikippp
PostPosted: January 26th, 2009, 15:38
Get PCB with close match(model, fw, dcm) and try it.
Users browsing this forum: No registered users and 168 guests
