ffocus:
To tell u the truth, I received many cases like this in my country. "Experienced" IT people even do this to salvage their company's data. And you know what ? I challenge them even to do my "easiest' problem, just undetected drives in BIOS without any problem of head knocking or rotor seizured. they may use any software/methods they ever know, but no attempt to open the hdd cover is allowed.
Unfortunately, they can not recover it after trying for weeks. Remember, all methods, all software may be used, but NOT OPENING THE DRIVE.
They had their conclusion that it'd impossible to recover the data without opening the drive, and then swapping the platter into another healthy donor drive, but they were still unsure how this could be done because from their experience, it's impossible to maintain the platter position when bearing cap of the rotor was removed.
Not until i show them how hard drive really works, why it should never be opened without correct analysis, why platters should not be touched and removed. what aligment is, what firmwares are, what makes drives detected in BIOS and how the algorithm of microprogram and electromagnetic head works altogether inside a hard drive..
The drive is probably the easiest to recover for DR people here, "The Notorious" Maxtor N40P. I recovered the data within 15 minutes or less. And yes, I did it without opening the drive's cover and swapping the platter to another donor drive. And that's a shock therapy for them. But that's the big prove for them. Data recovery knowledge, experience and technology are needed to judge, which case is recoverable, and which one is not, or impossible to do. I am not saying that I, myself, can recover every cases that easily, but the technology available for me is what made me possible to recover the data.
In your case, drive was opened and platters removed, it's not just alignment issue, drive's platter was already contaminated, it's a very impossible job for me to do. For me, reading the recovery fee is flat $.... for your case, no data no fee is a big question mark. yeah right, they'll try , and if you can't have your data back, you pay nothing, but in the end, you, the client lost. Lost of waiting for hours or days or weeks without any positive results.
Now those IT people i challenged previously, they really understand the whole internet "DR DIY" videos are BS at youtube etc, they know difference of FDB and SBR. The difference architecture of each drives from various vendors. Why keeping drive inside freezer won't work for modern drives and others internet hoax & BS they thought were true previously.
modern drives are not merely combination platters, heads and PCB. They are more than that.
And to answer your question, ffocus, seriously, it's impossible to recover your data now (at least for me - who is humbly not experienced enough to deal with your case)
Sincerely, Jonathan
_________________ My Forum
