 Post subject: Hdderase not working sata/abit
PostPosted: January 27th, 2009, 19:44
HI all
I've got an ABIT ip35proX motherboard, and 2 sata drives on 2 of the primary channels.
When i try and run HDDErase it gets as far as the screen where it SHOULD show you the drive list, but just stops there.
I burnt the bootable iso to cd and also tried the hdderase.exe on a different boot cd I made
I also tried running it from a usb pen drive but that dont work either.
I get the feeling its something to do with this motherboard?
I've checked on another computer and the program definately runs
but for some reason it wont run on this computer.
The drives are set to IDE mode in the bios.
I've also checked by trying it from a command prompt in windows (even though I knew it wouldn't work) but the program just hangs at the same point.
Anyone got any ideas?
 Post subject: Re: Hdderase not working sata/abit
PostPosted: March 23rd, 2009, 3:03
No suggestions, but I get the same behavior on an ABIT AB9 QuadGT motherboard. There seem to be quite a few mentions of HDDErase being incompatible with various motherboards.
Users browsing this forum: Himan and 101 guests
