 Post subject: how to protect a partition?
PostPosted: January 29th, 2009, 13:08
i have pc (tower) and windows xp installed, i want to do something like hp notebooks that have a partition recovery where you can't format or write files. i want to create a partition that can't format and write any files, but can't execute files in the partition.
how can i do it? without any software, only using windows or something else.
 Post subject: Re: how to protect a partition?
PostPosted: January 29th, 2009, 14:01
Hidden / locked partition.
PostPosted: January 29th, 2009, 15:04
how?
PostPosted: January 30th, 2009, 19:45
You answered your question by stipulating "Without using any software".
It will not be possible using just built-in utilities shipped with Windows. OK, it is possible, but it will be very complicated.
Consider using dedicated backup solutions. If you backup data to the same drive, it's not a backup anyway when that hard drive eventually dies.
Another option is to look into Acronis products. They are relatively inexpensive and do a good job at enabling you to recover in case of system failure.
Your most critical data should be backed up offsite. At the very least, setup a dedicated gmail account and e-mail the files to that account. It would be recommended to password-protect those files. One way would be to create a zip file and assign a password to it. This will teach you how: http://support.microsoft.com/default.aspx/kb/306531 :)
PostPosted: January 30th, 2009, 23:35
there is a solution to do this using GIGABYTE Mainboard. XRecovery software Bundled from Gigabyte can do this JOB.
Спасибо
СУТИОНО / АПИНГ
Users browsing this forum: No registered users and 311 guests
