 Post subject: WD2500BB-22GUC0 What is this component?
PostPosted: February 3rd, 2009, 6:36
A client plugged a 16.5v supply into their external.
I have a good donor board and completed a ROM transplant but the drive clicks, powers down, powers up, clicks, powers down......
Looking at the foam backing i can see that the component circled in the attached picture has been damaged (the same area on the foam is burned). Does anyone know what this component is please? Can it be removed/swapped from a donor board?
NB This is the clients board with the ROM removed. If i can repair this board i will put the ROM back natch.
 Post subject: Re: WD2500BB-22GUC0 What is this component?
PostPosted: February 3rd, 2009, 6:39
Sounds like pre amp is damaged.
PostPosted: February 3rd, 2009, 6:45
i was thinking that as well.
Clients board with clients rom - drive doesnt power.
Donor board with donor rom - drive clicks constant 'tick tick tick tick'
donor board with client rom - drive clicks, power cycle, clicks, power cycle.
because the heads acted differently each time i was hoping it was PCB incompatibility rather than heads. but then with all WD drives in the past, a ROM swap has allowed me to access data.
I may as well swap that component over anyway and see what happens, unless anyone tells me not to in the next few minutes :) in case i cause a rip in space time or something.
PostPosted: February 3rd, 2009, 7:03
i can't see it doing harm but its a waste of time.
test pre amp.
PostPosted: February 3rd, 2009, 7:08
Almost certainly preamp/heads.
PostPosted: February 3rd, 2009, 7:11
yep. time wasted :) will look at heads. thanks all.
PostPosted: February 3rd, 2009, 10:58
Over that models, when the HDD has PCB problem when u put donnor PCB the HDD reach readiness, but passport should show the "alias code" from factory " Mammoth , XYZ...etc" and u got ABRT register all the time, if its knocking surely are MHA problems
Users browsing this forum: Google [Bot], Hardcore Games, WebClaw and 49 guests
