 Post subject: Broken pins on Seagate 7200.9 PATA drive
PostPosted: February 11th, 2009, 11:13
Want to perform a simple PCB swap. Do I need to match the model, p/n, firmware etc. or can I use a board with the same firmware but from a drive with a different capacity?
Any help would be appreciated.
 Post subject: Re: Broken pins on Seagate 7200.9 PATA drive
PostPosted: February 11th, 2009, 11:15
There is a lot of information about matching boards on this website.
If you do some research, I am sure you will find an answer to your question.
www.datarecoveryne.com
PostPosted: February 11th, 2009, 12:02
Sorry if this is a noob question, but I've tried searching and I seem to find conflicting information and just wasn't sure. Some of the answers are related to different hard drive manufacturers so I thought the matching criteria could be different.
Also, is it possible to just replace the connector?
PostPosted: February 11th, 2009, 12:04
If you are good enough at soldering and have the right tools, in 2 minutes you can do it.
PostPosted: February 11th, 2009, 12:15
That's where I would start.
PostPosted: February 11th, 2009, 12:39
Unfortunately neither. But I guess it might be easier to do this than to find a replacement board.
PostPosted: February 12th, 2009, 9:45
Can anyone guide me on how to remove the IDE connector?
PostPosted: February 12th, 2009, 15:00
No need to remove the IDE connector if 1 or 2 pins are broken just get pins from any seagate drive and solder them . If many pins are broken then its tough to change the whole ide connector , good luck .
PostPosted: February 12th, 2009, 15:33
go for swapping pins rather than connector :O)
PostPosted: February 12th, 2009, 19:50
2 broken pins; I'll give the pin swapping a try.
Thanks for all the advice.
Users browsing this forum: No registered users and 184 guests
