 Post subject: Help Firmeware SP0802N!!!
PostPosted: February 9th, 2009, 18:47
Help i have the firmeware but a don't know how-to flashing the .ISO file in my Samsung HDD.
Thx to all ideas.
 Post subject: Re: Help Firmeware SP0802N!!!
PostPosted: February 10th, 2009, 4:07
No.
a) Why?
b) Have you got the $10,000 tool required to do so?
PostPosted: February 10th, 2009, 7:36
He could probably use Vtool.... And no I don't know where to download it
PostPosted: February 10th, 2009, 13:09
I have the disk with lock protection and mi mother in the xbox is death and i have the second xbox to put the disk but the disk don't work because the protection and the protections is in the ROM because this i want to update my firmware!
If i wrong please correct-me,THX!
PostPosted: February 10th, 2009, 13:15
my mother is death too LOL..
PostPosted: February 10th, 2009, 13:18
I try explain in same kind of English.
Xbox needy big time with mother inside box with protections!
ROM may alot help not see good but bad
Time needed then understand mother bad not so and live can with this protection.
Good buy other xboxy with no protecty disky drive
Put Samsung SP0802N hard work fit insixew xboxy can be risky if picky
Best solution to protection is .......
PostPosted: February 10th, 2009, 13:45
Easy to laugh when someone makes an effort to explain themselves in non-native language. Poor form in poking fun at them. At any rate, it appears that the Xbox motherboard is dead and you are trying to transfer the hard disk from one Xbox to another. It is true that that XBox puts a custom firmware version on the disk which makes it unusable outside the box. You can search for similar postings on this forum detailing this problem. I frankly don't think the problem can be overcome with end user tools.
LOL
PostPosted: February 10th, 2009, 14:20
ahum
Not the firmware that is the problem. If it's an xbox 360 for example he will need to edit the first couple of sectors.
Yes I like to poke fun.. It was the exclamation mark that did it
PostPosted: February 10th, 2009, 14:31
http://www.xbox-scene.com/articles/hdd-install2.php
Nervana :roll:
PostPosted: February 11th, 2009, 11:44
If the firmware is TK100-24 or TK200-04 depending on the model, it's not the ROM. Try changing the PCB with identical PCB of identical drive and you'll see that nothing has changed, so the problem is in the DISK itself. If you were near here I could fix it immediately (reset everything on the drive) :(
PostPosted: February 12th, 2009, 14:47
He want to flash .ISO file to samsung .. :D
PostPosted: February 14th, 2009, 9:22
What?!
PostPosted: February 15th, 2009, 5:13
Thx to all ideas.
Users browsing this forum: hetmansoftware and 126 guests
