 Post subject: error hdd n40p
PostPosted: February 17th, 2009, 10:19
Hi to all! :mrgreen:
after to use loader of this error!
look
Нет ничего невозможного
 Post subject: Re: error hdd n40p
PostPosted: February 18th, 2009, 0:05
It easy.
Write any module1F (Disk) for error correction.
PostPosted: February 18th, 2009, 5:00
bad loader
try another loader
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: February 18th, 2009, 8:56
If different LODR does not work, select 'Read Resources from Database' and load Road Map from database
PostPosted: February 18th, 2009, 9:20
Look... logs
2009SAMO.txt [997 Bytes]
Downloaded 836 times
20096E40.txt [7.84 KiB]
Downloaded 821 times
PostPosted: February 18th, 2009, 21:34
27 1F 0008 0001 - - - DISK - disk ID module
