 Post subject: Are this drives compatibles to do head swap? SAMSUNG HD501LJ
PostPosted: February 19th, 2009, 4:46
If yes, how to know for next time? Witch parameters must be the same.
Thx
 Post subject: Re: Are this drives compatibles to do head swap? SAMSUNG HD501LJ
PostPosted: February 19th, 2009, 5:47
I believe heads are compatible, PCB is not.
PostPosted: February 19th, 2009, 6:15
I just done a head swap on one of these and when powered it tried aquiring then clicked. I left it clicking for 5 then it came ready and scanned fine.
PostPosted: February 19th, 2009, 6:21
PBC in theory is correctly...
There's anyway to know if heads are compatible even the PBC? Do you check by P/N?
PostPosted: February 19th, 2009, 6:55
Everything is INSIDE the drive. ;) something OUTSIDE ;) otherwise try...try...try on your own.
PostPosted: February 19th, 2009, 7:07
Same family, same code for heads (T166S), assuming head map is same (probably is), then head swap should work.
But like BlackST says, try it. Let us know here :)
PostPosted: February 19th, 2009, 7:10
Then let's make a Good speaker when head replacement fail :mrgreen: :mrgreen: .
Ok ok, will try in 2 hours and tell you how it goes...
PostPosted: February 19th, 2009, 13:17
Bad luck. The patient has a ring on the top, so we will wait until next patient come...
Users browsing this forum: Stritom and 223 guests
cron
