 Post subject: Strange Lacie 500GB external hard drive
PostPosted: February 25th, 2009, 6:33
I have a Lacie 500GB external hard drive SAMSUNG HD501LJ Where the power adaptor failed and the data is gone. Yes, GONE.
I have scanned the drives for HFS+ or any others but found nothing at all. Rstudio, nucleus, mediatools, x-ways, etc etc, nothing found.
Weird, does anyone have this experience in the past?
The drive Samsung HD501LJ checked using UDMA and all working fine.
 Post subject: Re: Strange Lacie 500GB external hard drive
PostPosted: February 25th, 2009, 6:35
How does the disk appear in Winhex?
PostPosted: February 25th, 2009, 6:44
Also check the disk in a hex editor (winhex). Save a lot of time. You should be able to see if data is on the disk or if it's all zero's. If 'data' can be seen try UFS Explorer, then try a file signiture search.
PostPosted: February 25th, 2009, 9:28
Winhex screenshot:
File header search, none found.
PostPosted: February 25th, 2009, 9:30
Is it the same values throughout the disk?
PostPosted: February 25th, 2009, 9:37
no, i see some different data when i scroll it down.
PostPosted: February 25th, 2009, 9:48
Was it your Lacie or from customer? I suspect some intervention...
PostPosted: February 25th, 2009, 10:00
Customer's, i asked did anyone look at it before me, he said nobody. :roll:
PostPosted: February 25th, 2009, 10:18
Is it encrypted? What about results from a file signiture search?
PostPosted: February 25th, 2009, 10:27
ahhhhh HDD Spaz, you have given me a brilliant clue now, the LACIE has biometric finger print , maybe its encrypted after all. I'll check it out tomorrow. thanks.
PostPosted: February 25th, 2009, 12:12
Not bad for a spaz eh? 8)
Ask your client to send his finger in the post. :lol: Or you could look for prints on the unit and mould it with synthetic skin. then place print over your finger, wallaa! Yes, I watch too much CSI.
PostPosted: February 25th, 2009, 13:23
I have worked with 128-bit AES encrypted flash drives where the raw contents look like this. That was my first guess.
PostPosted: February 25th, 2009, 13:26
Had one of these recently with the fingerprint scanner. Unfortunately customer would not send in his finger so couldnt recover :-(
Actually, customer was no help at all and as soon as I began explaining about encryption he requested his media back so never really got a chance to look at it. No doubt it will be difficult.
Good luck with it :)
PostPosted: February 26th, 2009, 6:00
thanks guys, the drive indeed encrypted, I chopped customer's finger off to get the data. :D
Users browsing this forum: Google [Bot] and 103 guests
