 Post subject: Seagate 1TB - motor dont move
PostPosted: February 28th, 2009, 18:04
Hi to all,
Received a disk seagate 1Tb that the motor dont spin.
The disk have 4 plattes , anyone could change the plattes to other disk and it works ?
Is possible to repair the splinde?
Ze
ZeBong
" Россия еще раз"
 Post subject: Re: Seagate 1TB - motor dont move
PostPosted: February 28th, 2009, 18:12
Hi my friend! :mrgreen:
Photo?
Нет ничего невозможного
PostPosted: February 28th, 2009, 19:05
If done properly, yes should work. To repair spindle it depends on what happened.
PostPosted: February 28th, 2009, 19:33
Just because the motor does't spin does not mean that the problem is with the spindle. Did you check PCB? Or do you mean spindle is stuck?
PostPosted: February 28th, 2009, 21:44
Check your PM.
http://www.datasaversllc.com
PostPosted: March 2nd, 2009, 9:29
Hi to all,
here is the photo,
The heads can move the the splinde dont move.
ZeBong
" Россия еще раз"
PostPosted: March 2nd, 2009, 9:36
U have a little hope the heads are on land zone thats good , and maybe its possible to "free" the spindle without platter exchange
PostPosted: March 2nd, 2009, 10:23
Verify PM.
PostPosted: March 2nd, 2009, 10:44
Thanks to all
Will report the sucess :) if it works :)
ZeBong
" Россия еще раз"
PostPosted: March 20th, 2009, 18:53
I have this exact same problem in my office right now. I have managed to release the stuck spindle (Very carefully.) but the drive still gives me the same symptoms.
According to current monitor there is a spike to ~900ma max for ~1 second then it will drop to 0, and a second later will attempt again.
I have a identical PCB on hand, and it give me the same results, also putting the PCB from this drive to a known good drive the drive will spin up fine (not identify of course, but spin up)
I am guessing that the circuit on the spindle itself is likely damage, I am here for any input I can receive.
It looks as if a platter transplant maybe in order for this drive.....sigh
PostPosted: March 20th, 2009, 19:06
you can try with a tool like this :
Stuck Motor
ZeBong
ZeBong
" Россия еще раз"
PostPosted: March 20th, 2009, 19:17
I have 100% for certain un-frozen the spindle at this point. It moved completely freely with no problems. But it seems the motor can still not spin the platters up; This is why I think the circuit on the spindle itself may have been damaged.
PostPosted: March 21st, 2009, 0:39
Yes i had check that change the PCB and test of course u know what u need to put on Donnor righ? , if heads was not moved by a dropped, u could be get look , spins and could be reach readiness unfortunely at 2 cases wich we receive was dropped, spindle stucked, heads moved to the begin of platter´s at both cases, we "free" the spindle, but not was sucess doesnt reach readines,s the another reach servo marks, but no SA, so we did platter swap, and same problem , still´s the problem , looks like excentricity problems
PostPosted: March 21st, 2009, 7:14
I think that it could be that the heads preamp burnt out, thus, it will need a headstack replacement.
PostPosted: March 21st, 2009, 11:23
zebong wrote:
Hi to all,
I did. Platter swap against this model could be done, but with a lot of difficulties. Drive reached DRDY and DSC (with significant delay - not to mention humming sound) after platters and heads swap. I successfully cloned about 1,450,000,000 LBA sectors (+- 712 Gb) until it stopped working and heads starting to knock. Luckily 95% of most wanted data recovered.
Ze
Too difficult, I think it's painstaking and useless.
My Forum
PostPosted: March 23rd, 2009, 11:48
I have had some of these as well. Tough drives to work with =(
Users browsing this forum: Google [Bot] and 62 guests
