 Post subject: problems with Seagate ST3500630AS 500GB
PostPosted: March 6th, 2009, 4:09
Hi all
i am having an issue and am a bit stuck
Got the above drive in, initially it would not ready and shows errors in terminal as below
Reset
4096k x 32 DRAM
GALAXY3D - 1_Disk S-6B 06-29-06_12:12
HM SFI
$HM SFI
ERR Read Boot Adapts
F>
Recieved my exact donor and replaced heads ( donor is a perfect match)
i reaplced the heads, connected tp pc3000, drive powered up and became ready, all good so far, launched DE and cold see partitions,
i powered down so i could install a drive to image
when powered on again the drive will not become ready, and will not id
i get the below terminal results
Reset
4096k x 32 DRAM
HM SFI
(P)SATA Reset
$SFI
AMR
$SFI
AMR
Failed sys sect. write! Nwt Er 33 RdWr 15fe9.00.0003
DiskAccess ReadSector EC=47 at ffffffff.00.0002
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 15fe9.00.0002
Unable To Load Overlay 01|000A
T>
i am lost here, can anyone share some info on this one please
thank you
 Post subject: Re: problems with Seagate ST3500630AS 500GB
PostPosted: March 6th, 2009, 4:15
Let this be a lesson to you. Once it's working, don't switch it off! Also be better prepared. Was the work done in a clean room? Maybe some debris has been swept across the platter over SA. Possible that new heads are now bad.
PostPosted: March 6th, 2009, 4:18
i always have a drive attached for imaging but just one of those which i overlooked this time.
yep all work was done in a clean room, platters were completely clean when drive reassembled.
PostPosted: March 6th, 2009, 4:21
Put the heads back into the donor drive. See what happens.
PostPosted: March 6th, 2009, 4:31
i was thinking of that but wanted to minimise moving heads back and forth again as the drive was hard to source.
thx for replies
PostPosted: March 8th, 2009, 1:32
HDDSPaz
as i could not progress any further i did swap heads back into original drives, so the donor head is back in the dopnor drive as disucssed and the donor drive works perfectly fine. this indicates that the work in replacing the heads back and forth is all done 100% successfully with no damage.
The original heads from the patient are back in the patient and the follwing is appearing
HM HM Reset
4096k x 32 DRAM
HM HM HM HM HM HM HM HM HM HM HM HM HM HM HM HM HM HM HM HM HM HM HM HM SFI
$SFI
AMR
$HM SFI
$SFI
AMR
$SFI
AMR
$SFI
AMR
$SFI
AMR
$SFI
AMR
$HM SFI
$SFI
it sounds like the drive is spinning up, a small click and possibly not reaching correct operating speed.
When i install the donor board to the patient drive i get exactly the same log as abov.
When i install the patient board to the donor board all works perfectly well.
So this rules out the heads and the controler board.
I am suspecting possibly spin up speed issues due to problem with motor.
As a final test which has not been done i guess i can install the patient heads to the donor and see what happens. but before doing this i would like to see what your /other thoughts may be with this one.
Has anyone experienced spindle speed problems ?
thank you
PostPosted: March 8th, 2009, 4:33
whats the history with the disk? Was it dropped? I suspect damage to the media.
PostPosted: March 8th, 2009, 5:05
I don't believe it was dropped it was in a customers desktop worked fine one day and not the next
When I had it in the cleanroom again today for head swap I checked again for scratches and can't see any with microscope
I guess it only leaves media or spindle damage
Will do some more tests and post
Thx for replies and input much appreciated
PostPosted: March 8th, 2009, 5:09
You can get sratches on the underside of the platters too. Rule of spindle failure but swapping the platters but I seriously doubt this is the fault.
PostPosted: March 8th, 2009, 5:19
If it is a scratch on the other platters I would of mabye expected some dirt on the filtercwhich if clean
And then there is the heads from the donor which worked fine for a minute in the patient then stopped working but work fine in the donor again which I would think would rule out media damage
But discssing this is making me think more clearly :)
Thx
PostPosted: March 8th, 2009, 5:49
Personally this is what I would do now.
Platter swap, then test.
If no different, source another drive then hot swap, then test.
The filter doesn't always get dirty when media damage occurs.
Users browsing this forum: No registered users and 254 guests
