 Post subject: Drive Hitachi 2.5 with plates moved
PostPosted: March 9th, 2009, 17:48
I work in to company datarecovery, I have to drive hitachi de 2.5 with problems in head. I have the donor but the drive with problem in the heads have the plate moved top. how I can move the plates to position original or is impossible?
Thanks for your replys.....
 Post subject: Re: Drive Hitachi 2.5 with plates moved
PostPosted: March 9th, 2009, 17:59
:shock:
PostPosted: March 9th, 2009, 18:18
:smokers:
PostPosted: March 9th, 2009, 18:42
ja maybe he its trying to tell us , one platter was moved and want to know how to return to the original position if was lost the original alignment, could be possible but u need a lot of equiment and a high level of experience to decode signals , and find the correctly position
PostPosted: March 9th, 2009, 18:59
I think there is more than that problem...
PostPosted: March 9th, 2009, 19:50
I see two problems,
Aligment and Heads.
Wich model off the disk is ?
ZeBong
" Россия еще раз"
PostPosted: March 10th, 2009, 6:55
You almost sure? How did this happen?
Angel Data Recovery
PostPosted: March 10th, 2009, 7:48
The drive model is IC25N060ATMR04-0 HITACHI 60GB 2.5"
PostPosted: March 10th, 2009, 7:51
Hi DR-Kiev
our clients uncover the drive and manipulates.
PostPosted: March 10th, 2009, 9:57
It is NOT impossible but it will be MUCH EXPENSIVE. And the chances are medium-low.
PostPosted: March 10th, 2009, 11:58
markcarq wrote:
Hi DR-Kiev
There is often a head stick and your clients could just move both platters (not separately).
Torture your clients . Learn the truth . :D
PostPosted: March 11th, 2009, 4:05
As Dr. House says: Everybody lies :lol:
Dobre
Murphy was an optimist
Users browsing this forum: No registered users and 284 guests
